OK I will give my initial impression as requested. I wasn’t going to as I am no expert in headphones etc. I come on here to get advice rather than to give it to be honest
First things first the instructions are not good at all, I followed them exactly and I could not pair the earphones or connect them. Eventually I succeeded but this was time consuming and I succeeded by luck rather than the instructions provided.
I swapped the flange and tips for large and the fit was OK, pretty snug actually , at first I was pleased with this , but later realised that they do move about when I move….or even smile
First impressions soundwise was not good if I am honest. Bass overpowering everything , muddy as hell , could not hear any treble detail at all. The EQ is A MUST! So I have boosted the treble a little and tined down the bass too and it sounds a lot better. The Balanced option in the EQ was horrendous to my ears. Muddy , cloudy not so much a veil over the music …more like a big thick bath towel
They are a bit fiddly to get in the ears too, and I end up turning them off sometimes when doing so, although I suspect this is my mishandling of the units until I get used to them.
The big plus so far is the EQ, its excellent and very responsive , the changes are very noticeable and they are immediate. I am still to get the sound I want but I will keep trying some options .
My main issue is I am struggling to charge them , been charging over an hour now and according to the App they are not charging, ie the percentages are staying the same. Again I will have to get the manual out and see what I am doing wrong ….it certainly a VERY TIGHT fit into the case so I am not sure I am placing them in the case correctly.
I just want to stress that I bought these for convenience and occasional use when lying in the garden in the summer for example so I was not expecting them to blow my mind.
My other gear is quite good too so I feel I may be a tad spoilt in this area.
Overall I need to hear more detail than what I am hearing. I have the ER4XR and I guess this is the sound I would like to get close to ……I will keep experimenting with the treble to see if I can get closer to that sound.
Only had them in for an hour and the ears are very itchy, like uncomfortably itchy….so I will have to see how this goes. I always use Comply foam tips for better comfort but not sure how they would go with these, and I certainly would not get them in the case
It sounds like I am not that impressed, but its early days and they are a convenience buy for me, They will be used sparingly I would imagine …..but I wanted to share my first impressions.
For me there is still a huge gap between wireless and wired from what I can hear. However in the past I have found new gear takes a little bit of adjusting to so I will continue to listen and experiment with the EQ.
