Going fully Wireless IEMs. Too soon? Or are we there yet?
Feb 10, 2021 at 5:07 AM Post #29,131 of 38,544
Caipirina
I don't want to put a damper, but has anyone been surprised at the sound quality of wired iems/headphones after using wireless for so long? I've been using Airpods Pros for a very long time, which I thought sounded decent. I then recently got the Galaxy Buds Pro, and those sounded even better, albeit less comfortable. I decided to chuck 20$ and get the Sony MH750's and was blown away at the sound quality compared to my wireless options at a cost of 1/10 of the Buds Pro.
I actually had a reverse experience the other day, tried a few of my wired IEMs and as soon as I dared moving I could hear the rustling of the wire against clothing / skin / beard ...
Feb 10, 2021 at 5:20 AM Post #29,132 of 38,544
chifihead
Indonesia
The gist makes sense, but not with the MH750s. I would say you just like the tonality of the MH750s more.
Did you try using the app with the Buds Pro, and changing the EQ preset? If you like the MH750, the "Clear" preset might tickle your fancy.
Oof, yeah I hate that! That's what makes aftermarket cables worth it.
Feb 10, 2021 at 6:35 AM Post #29,133 of 38,544
diimaan
Weil am Rhein
First review declares it "best" :) for sound(if you like clear and tight) but not best for noise canceling. I suspect some better fitting might improve the noise cancelling and the sound to not be as "cool". Control scheme is not the best and leaves out rewind.
It’s been five days since I made the purchase in their EU page. I live in Germany.
I contacted KEF support on Facebook, they responded by saying shipping will begin in approx 8-10 days due to the Pandemic.
I will update here once I get them :)
Feb 10, 2021 at 11:27 AM Post #29,135 of 38,544
Lorelock
USA
Anyone using Fiil T1PRO have any EQ settings they can recommend?
They are really good sounding with more bass than I expected based on every one saying the earfun free pro is tuned for more bass out of the same bud. I find even in the treble preset there is plenty of bass. It is not quite to 75t level but easily matches 85t and can surpass it in bass boost mode over stock 85t settings..
Hello, new user here and owner of the FIILs. I'd like to share this EQ setting for the T1 Pro. If possible, may T1 Pro users please try this configuration in the FIIL app and let me know how it sounds? This aims for a deeper, bigger bass while retaining control, raises the lower mids a fair amount to boost warmth while keeping clear of muddiness, and slightly reduces the treble peaks present from 2k to 8k in the T1 Pro. Essentially, this aims to achieve the best of both worlds: the earfun free pro bassy sound without the somewhat-intrusive and sloppy bass, and the fiil t1 lite balanced sound with reduced treble harshness. (Note: I use the stock eartips on the T1 pros)
https://imgur.com/a/tijTktr
For precise values, you may input these on a digital EQ app:
30 = +3.5 db or +3 db
60 = +3.5 db or +3 db
125 = +3.5 db or +3 db
250 = +1.5 db
500 = 0 db
1k = 0 db
2k = -1 db
4k = -3 db to -2 db
8k = -3 db or -2 db
16k = 0 db
EDIT: cut for 4k and 8k changed to range from -2 to -3. The former to preserve more presence and detail, the latter for less fatigue and added bass presence. Also changed to +3 db for bands from 30 to 125, less mud and more natural sounding lows.
Feb 10, 2021 at 12:30 PM Post #29,136 of 38,544
mbk
This is the best I could do with my phone's camera.
Grado size S on the left, Sennheiser size XS on the right.
Comparison between Grado size S, Sennheiser size S and XS.
Dimensions are similar as you can tell. Sennheiser S is a little taller than Grado S. I use the Sennheiser XS on my Grado's.
I'm not sure why they sound different as I did have a good fit with the Grado ear tips. I suspect maybe the silicone is different? The Grados do feel a little flimsy compared to the Senns which are a little more dense.
I highly recommend the Sennheiser tips though if you're not happy with the sound. They can be had for $11 directly from Sennheiser.
***I tried the stock ones again just now just for kicks and I immediately could hear the droney overpowering bass.
All sizes out of stock in Sennheiser site. Since you have the different sizes of both, which Sennheiser size is most comparable to the Grado medium? That’s what fits me the best.
Feb 10, 2021 at 2:40 PM Post #29,137 of 38,544
Canabuc
30 = +3.5 db
60 = +3.5 db
125 = +3.5 db
250 = +1.5 db
500 = 0 db
1k = 0 db
2k = -1 db
4k = -3 db
8k = -3 db
16k = 0 db
Tried it was nice but felt I needed more treble than that but agree to drop the mids and I boosted upper treble to get more detail
Feb 10, 2021 at 3:50 PM Post #29,138 of 38,544
SemiAudiophile
I would go with the Small ear tip. The height is about the same as the Grado Medium maybe just a tiny bit taller, but the Grado's are fatter as well.
The Sennheiser Mediums are surprisingly shorter than both but fatter than the Grados.
I guess it depends on your fit? If you want it to be deeper in your ear or if you want better seal?
Feb 10, 2021 at 4:07 PM Post #29,140 of 38,544
tinyman392
Be nice to noobs, we were all noobs at one point in our life.
@SemiAudiophile those Sennheiser tips look similar to some generic ones that HiFiMan used to offer with their IEMs. I think Heir Audio (from like 5 years ago) did the same. They were very good tips though. HiFiMan no longer offers those tips and Heir Audio doesn't exist anymore, the main person in charge went on to create Noble Audio.
Feb 10, 2021 at 7:12 PM Post #29,143 of 38,544
Canabuc
First few listens with MTW2. I know late to the party.
Expected more to be honest.
Bass is good. Vocals good. Wide soundstage.
But lower mids seemed like the bass bled into them. Volume is low too had to go to over 80% whereas the Jabra would need 65 and the Fiil 70.
Once EQ'd I really enjoy the Fiil t1 pro sound. Similar to Jabra when both EQ'd but with the treble detail being a bit better.
Outside of the Chinese app and a case lid that closes too easy all the time these are quite the steal.
ANC and ambient are not class leading but full controls great fit and comfort and sound with Qi charging and a tiny case for 60$! US
Feb 10, 2021 at 7:18 PM Post #29,144 of 38,544
erockg
Los Angeles, CA
intersting! Im looking to replace my faulty Geminis. Waiting for the KEF Mu3. Would you say the Grado’s sound better than Geminis?
Yeah, I just packed up my Gemini's for a return. I'll revisit when they fix things. I think the Grado's sound more natural, but still listening. The soundstage is comparable and the fit is also more secure. I bought them from Crutchfield here in the US. They shipped FAST.
