Stax TWS earbuds. Not likely to have an electrostatic driver, but hope it is not just Edifier rebrand.
Of course it would be. Mind you, some of the TWS IEMs I've tried have been pretty good.
According to a Japanese review, if you set the app eq to "Warm" (perhaps the wrong translation?) then you get the N6Pro equivalent vocal presentation.My Nuarl N10 Pro arrived few days ago. was surprised my local dealer in Australia stocked them on Jap release date. got it the next day matching the YEN retail price. Not sure if other dealers have them in stock but you can find the Aus dealer link on the Nuarl dealer list.
Didn't have much time to listen to them. but my initial impressions are it has much larger sound stage than the N6 Pro. One of the widest sound stage TWE i've listened to. The sound stage expands about 5cm-7cm outside your ear. the N6 Pro sound stage is around the base of your ear.
The sound presentation is more cold analytical. Compared to the N6 Pro it sounds colder brighter. N6 Pro has a warmer forward vocal presentation while the N10 Pro has more detail and the vocal doesn't seem to be forward like the N6 Pro. with the wide sound stage the separation and positioning of the instruments are fantastic.
I had issues with the eartips. while i usually use the spiral dot on most of my buds but it seems to leak sound on the N10 Pro. Had to use the foam tip that came with it to have a proper seal and boost up the bass. If you look at the earpiece design below the earbud stem is shorter than the N6 and the Sony so it doesn't reach deeper inside your ear. If i press the earbuds into my ear i feel there is a significant bass increase. with the stock foam tips the bass is about the same as the N6 Pro. might try some longer foam tips for a extra boost. The sound quality definitely is better than the N6 Pro...unless you prefer warmer vocals.
The size is to the larger side. the charger case is much longer too. the buds are about the same length as the N6 but its much thicker so it will stick out. its still smaller than the sony though.
Haven't played with the App or tested the ANC yet.
as a display of typical human nature, although I'm currently satisfied with my TWS collections and the BT20S Pro, i still purchased this Tronsmart Onyx Free anyway, out of curiosity
aside from the less than stellar mic quality (testing it with Voice Recorder), i really like this as a total package. Balanced sounding, soft clicky buttons, velvety rubber coating on the case, small case and unit size, able to use regular tips, full control, and APTX (for those who care).
here's size comparison to the Gbuds
Mind letting us know the actual battery life?
I was disappointed in the Spunky Beats only lasting me around 3hrs instead of 6-7 claimed.
Granted I don't have a phone that currently does TWS+, even though it's SoC is capable of it (Damn you Google!).
Hey guys I bought my first pair of earbuds a few days ago, the Boltune BT-BH024 and they sound great and I have just ordered some memory foam eartips, as the silicon tips slightly hurt my ears after wearing them for a short time and they also slip out, only a few milimeters but enough to effect the sound quality....So hopefully I'll notice a improvement with the foam tips, but apparently the foam tips wear out quickly, just how quickly are we talking about?
Anyone spend time with the new Sennheiser CX 400 TWS? Price seems high for what they are, but there's not much else new out there and apparently money burns a hole in my pocket.
Seems it is the Edifier but, IIRC, these are not sold but an included gift when you buy a certain STAX headphone.Stax TWS earbuds. Not likely to have an electrostatic driver, but hope it is not just Edifier rebrand.
I suspect Nuarl will continue to sell n6p along side n10p, because they have different features and price points.The n10p will be the successor of n6p. It is not released yet, I think. It is Nuarl flagship model if I am not mistaken.
