so the Apollo Bold has finally arrived.
i only been testing it for half an hour or so, but here's some of my initial impressions:
build quality is good. the unit itself are nicely built and looks classy. the case is light and small. it's plasticky, but i like the battery indicator and that the flap stays open and not slams itself shut.
I'm never a big fan of touch buttons in general. here the buttons are responsive enough to the touch commands, but i think the touch area is too wide, as it always registers a touch everytime i try to put it on or remove it from my ears, and i did try to hold it on the edges.
i also like that the touch won't register when removing it from the ears, but i really wish i can turn the auto pause function off. but i don't know if this unit will ever have an app support.
now the sound. first, i want to confirm what other members already discovered: with ANC mode and Ambient mode on, the bass amount would increase quite a bit. with the stock tips, the ANC off mode has just enough of bass for my taste, so on ANC/Ambient mode (they share the same bass boost signature) it's a bit too much for me.
compared to the Dyplay BQC35 that i have, it doesn't change sound signature at all, but the default sound is bassy as it is (think of the Jabra 65t unEQed).. and it's a bit similar to what this Apollo Bolt sound in ANC mode,with the Bolt sounded warmer and mids a bit reduced.
so i tried using the Reversed KZ tips that i use with the Dyplay on the Bolt. the bass is reduced, but still a bit fatiguing, so might need a bit playtime to see if the bass would settle a bit more.
i don't have a problem with the overall mids and treble of the Bolt, sounds good to me.
ANC blocks to mid freq stronger than the Dyplay, but not as strong as XM3. granted, this also apply to the passive noise blocking, as the XM3 have better passive isolation than the Bolt, and the Dyplay basically almost doesn't block at all.
using, plane cabin sound simulation, they all have a good job cutting out the rumbles, and let in chatters respective to their passive isolation capabilities.
i also like the Ambient mode. you'll definitely know it's feeding through a mic, but it lets in clear sound.
volume can also get crazy loud with this, so a lot of headroom for people who needs it
i haven't had the chance to test the battery life, call quality, and ipx rating capabilities yet.
overall this is a solid product. Tronsmart did sent this to me for free, but i personally say this definitely worth the price.
