clerkpalmer
- Dec 16, 2015
Received my MW07's this morning. First impressions are: stunning presentation, design and build quality. Disappointed there's no app, so it means no firmware updates possible.
Sound-wise, I heard no hissing that another user experienced. Bass is a little stronger than I'm used to, but it's not deal breaker. The default fins and tips were a great fit, I don't know if I should change them since they work so well. The sound in other areas is loud and punchy, the tips seem to isolate the music well in my ear canals.
Once i put them in, I have to be honest they were almost invisible in terms of feel. You can just about feel they're in there, I don't know if that's a good or bad thing yet. If one fell out, would I notice I guess is the question?
Build quality is so good, solid, strong, and clean.
Charging case is equally beautiful. Comes with a huge range of tips and 2 sets of fins, and a usb-c cable with a usb-c-to-a adapter. The only negative thing about the case is it's a finger print magnet.
Overall, I'm certainly pleased with them. Tomorrow will be the litmus test, when I go out though, and see if there's any wind interference, drop outs and such.
Thanks for the impressions. Glad to hear you are not hearing any hiss - hopefully mine were just a bad set.
