CocaCola15
- Feb 22, 2015
I don’t even turn on the app. I just connect the L2P via BT and adjust their flat sound with the player I have, Kaisertone Audio. And as noted, there is a flat setting in the Soundcore app.For this to be a viable option, there would need to be a flat/no EQ setting in the app, so that you can use it as a clean starting point to use your player's EQ. Otherwise, you'll just be layering two different EQs on top of each other, which is probably not ideal. Anker should really add a no EQ option to the app, as well as a user customizable EQ, as others mentioned.
Plus, layering the EQ is not problematic if it sounds right.
