Not much talk about the Echo Buds, it seems only three of us here have gone for them ? And I had to jump through hoops since I'm in Europe
After an initial "scare" when I used the Jabra Elite Sport tips (used by
@rhsauer and that normally work for me) gave me a tinny sound, I'm really happy with them. I alternate between the L stock tips and the L CP360, the latter give a perfect seal but tend to "push" them out if I talk. Now the EBs have a "trump card" with the wings that do a great job keeping them right where you put them in your ear. In the long run this causes a little bit of discomfort so I'd reserve them for when you're on the move.
The SQ is excellent, all the frequencies are there and the presentation is very "sharp", quite the opposite from the APPs slight "muddiness".
The ANR seems "mild" at first (not the "wow" effect you get with the APPs) when you toggle it on/off but it does the job especially since the passive isolation is quite decent. The transparency mode sounds less natural than the APPs but it does the job, at least as well as the 65Ts I'd say, maybe better.
I'm not a heavy user of Alexa but it's convenient to ask for volume up/down or to play a radio feed without having to tap a button to activate "ok Google".
Highly recommended !
