Going fully Wireless IEMs. Too soon? Or are we there yet?
post-15294638
Post #15,091 of 26,810
sanity8me
This review is pretty spot on from my experience. Definitely think that without connectivity issues and lack of AAC, the mw07+ are among the best on the market right now for everything except ANC (which is passable at best). SQ is on point for sure particularly with some mid-preference EQ.
Also, I'm willing to try to create a new thread, the only issue is we need to get people behind it to switch over.
Airpods Pro review coming either later tn or tomorrow.
I think that would have to come naturally, but if you start with a first post that has an extensive list of all the well known and highly praised options mentioned in this thread, especially the well known chifi considerations, that would be amazing and super helpful. The community needs it. I don't think it's an easy task though. I also recommend to have links to some of the superb reviews/impressions from this thread.
I mean let's face it, wireless is the future and, even if it's not there yet SQ wise, many of us, including myself, will gladly sacrifice a bit of SQ potential at a certain price range for the sake of convenience and comfort.
post-15294639
Post #15,092 of 26,810
Blueshound24
Mt Rushmore State
Mt Rushmore State
I just have to share a rant I placed on the Shanling thread about something that I'm sure others have complained about before.
Why don't TWS earphone makers make a case that larger ear tips will fit. Why not just make a bigger hole for them to fit into? It is so frustrating to have to take them off and put them on every time to charge them. :triportsad:
TWS manufacturers I'm talking to you!
post-15294645
Post #15,093 of 26,810
wizll
also just got my replacement lp2 and put it through the paces. while I still hear when the audio initializes the white noise is noticeably quieter than my older unit. at first, I thought it was no different, then I put on my old ones and it was much more present than I remembered. maybe i had gotten used to it. in any case, I'm satisfied as the sq is just as great.
post-15294659
Post #15,094 of 26,810
tma6
NY
NY
I'll see what I can do to compile that info and start a new thread. I think I'll start by laying out a partial list here and have people weigh in if they don't see something that should be on there.
Reactions: sanity8me
post-15294681
Post #15,095 of 26,810
sanity8me
Godspeed!
post-15294683
Post #15,096 of 26,810
ngd3
Do it as a "True Wireless IEM ranking" thread. Then most posts will be rankings, reasonings and pros/cons. Would be a great way to condense opinions for all to dive in and narrow down what might suit them
Reactions: tma6
post-15294706
Post #15,097 of 26,810
sanity8me
Agreed. Although I believe some true wireless earphones aren't really considered "IEMs".
Also, I think comparisons should be highly encouraged and recommended, and that goes not only against other TWS earphones, but against well known wired earphones so people on this site can have a better impression on what to expect.
Reactions: Blueshound24
post-15294720
Post #15,099 of 26,810
d3myz
USA
USA
This is interesting. Very into the Tevi signature, but def would like some more low end. How are they for phone calls?
Much better for phone calls than the first version.
Reactions: tma6
post-15294898
Post #15,100 of 26,810
gibletzor
USA
USA
I'm 99% sure the stock tips for the Echo Buds are exactly the same as the Galaxy Buds, and I hated those stock tips. So far my leading candidate for retaining sound quality and still being able to charge are my MS JVC Spiral Dots. I've tried my Tennmak Whirlwinds and Spinft CP-100Z also and both sounded great but either wouldn't sit right to charge or were very hard to get sitting in the right place. The MS Spiral Dots snap into place more reliably. I don't have all my tips with me as I'm at work so I'll let you know when I get a chance to try more!
Meh, the Spiral Dots are pretty finicky to get seated right to charge too... This charging case may be the downfall of these buds.
@webvan So my suspicions about the Echo Buds and Galaxy Buds tips being the same was partially right. They're the same style of shallow insertion, narrow bore tip. They would be a wide bore tip but they've got that rubber lip that cover a good portion of the bore to make it smaller for who knows what reason... The biggest difference is the Echo Buds tips are slightly shorter and slightly fatter overall, but the biggest Echo Buds tips are the same size roughly as the medium Galaxy Buds tips.20191107_202859[1].jpg 20191107_202915[1].jpg
In the pictures I added, the Galaxy Buds medium tips are on the left, the Echo Buds large tips are on the left with the blue inside.
So far I've not been able to find a tip outside of this style that will allow the Echo Buds to charge reliably. I've got a couple other similar looking sets with wider bores coming from Amazon this weekend. Otherwise, they sound phenomenal with Spinfit CP-100Zs Medium, JVC Spiral Dot MediumSmall, Medium Auvios, and Medium Tennmak Whirlwinds.
Reactions: d3myz and actorlife
post-15294947
Post #15,101 of 26,810
webvan
Thanks for the pics. I'll see how they work for me when the Echo Buds arrives but I generally prefer wide and shallow tips for comfort, a bit like the Jabra Elites Sport, 65Ts (not quite enough to my liking) or the LTA+'s. There can be issue with maintaining the seal with this kind of tips but the Echo Buds have optional wings to take care of that problem it seems.
Having compared the MPOW M5 with the Final E LL and with the Jabra Elite Sport L tips, I find the latter have more "sparkle". The Final E LL are more secure in my right ear but make the bud stick out too much from my left ear and as often (always?) mixing different tips (unless it's just the size) creates an imbalance and different coloration.
post-15294950
Post #15,102 of 26,810
gibletzor
USA
USA
Thanks for the pics. I'll see how they work for me when the Echo Buds arrives but I generally prefer wide and shallow tips for comfort, a bit like the Jabra Eliste Sport, 65Ts (not quite enough to my liking) or the LTA+'s. There can be issue with maintaining the seal with this kind of tips but the Echo Buds have optional wings to take care of that problem it seems.
I haven't been using the wing tips at all yet. They tend to hurt my ears more than the extra stabilization helps, at least on my Galaxy Buds they did. I'll try em out this weekend maybe.
post-15294954
Post #15,103 of 26,810
gdv brisbane
I'm coming to TWS having been a long time Etymotic user (ER6i to ER4P to HF3). Is it too much to expect any current TWS to equal the transparent resolution and sparkly highs that I get from an Ety BA driver? I tried the APP yesterday but they were "muddy" compared to my Etys, where I feel like I can hear every string on an acoustic guitar ringing out. It would be good to know if I'm expecting too much from TWS at this stage.
even other wired IEMs will have a hard time matching the Ety signature sound, and that kind of sound would only works in noisy environments with that Ety deep insertion.
Thanks for the advice. I'm hoping that the Amazon Echo Buds may offer something similar to the Etys as they have dual Knowles BAs and seem to be deep insertion. They also fit the Comply foam tips and so are closer to my current Ety+Shure Black Olives set up (old school, I know...).
just be cautious that Knowles driver types are plenty, and sadly not many products would state what type they are using. for instance, i have the Earin M2 which is a single Knowles driver, but the sound is anything but the Etys. it sounds so much warmer in comparison. the Galaxy buds which has micro dynamic driver can be set (via app) much more similar to the Etys, because it has similar lean mids and similar peaks in the mid-highs
Can anyone with the Echo Buds comment on their SQ compared to the APPs (higher end) and/or the SSKs (lower end). I appreciate they're half the price of the APP but I'm trying to gauge how much of a compromise they are. I'm also trying to not be too shocked compared to my Etys...
post-15294982
Post #15,104 of 26,810
webvan
That's awesome!
I'm glad they are still showing some interest in this market, they have been out of stock for 5 months at least. My M2s are definitely one pair I would never sell. I hope there is a M3 as I would absolutely buy one.
Isn't fit/comfort a bit of a concern though , I did not manage to get a good fit with their clone, the Tiso i5, regardless of the tips I used. I'm guessing the foam eartips of the M2 do the job but are apparently not available as replacements ? Well they recommend Comply tips but on the Comply site people are complaining that they are not the same as the stock ones and don't work well...
As a side note, I could swear I read here the other day that the Earin website was for sale ? Or maybe it was that they M2 were no longer on sale :wink:
post-15295004
Post #15,105 of 26,810
pokenguyen
I'm really torn between MW07+ and Sony WF-1000XM3, the sound (after EQ Sony) are quite close. MW07 vocal is thicker and more emotional than Sony and plenty of bass, while Sony has more bass and at half a price in my country.
Users Who Are Viewing This Thread (Users: 14, Guests: 40)
