tkam
I'm not quite sure if this is the place to put this, but I figured it's time to give back to the community that I have enjoyed and learned so much from over the past few years. So I've decided to offer free picture to hosting to anyone in the community. You can do so by going to : http://gallery.stainlesseternity.com and click the login link in the top right hand corner and use the following login information:
After you login you can create a new "album" for yourself and add as many pics as you want I don't have any bandwdith restrictions so don't be concerned with that. All I ask is that you do not give out the username and password and when creating an album name it after your head-fi username so that I can make sure only head-fi users are using it.
*note* - you might need to turn off any pop-up blocker you have enabled.
