Garbz
- May 19, 2004
Hi all
I just fired up my Gilmore for the first time and now i'm working through the niggling problems. I just managed to tame the -ve opa548 by adding a 0.12uf capacitor between pin1 and 2 (-vin +vin). This brought it down to a manageable temperature and i can keep my hand firmly on the psus now without anything cooking. Generally it's still hot but then again that's what the heatsinks are for in the first place right
Anyway back to the problem. I've confirmed and noticed the following:
1. The voltage output is +16.25 -16.20 from the psu. Which seems acceptable enough.
2. The output transistors of the amp itself are hot to the touch, but not burning hot, as is the servo for which i've used opa227.
3. All LEDs light up
4. When various LEDs are in the output DC swings around a bit between +- 1.5v. The lowest i've managed to get it was 0.8v
I assume that when i remove the LEDs that the servo stops working as the voltage stablises. The right side has -1.147v and the left side has +0.988v all relative to ground.
The main problem i think was the transistor matching, I kinda had no idea what i was doing. The resistors were all matched very closely (i'm using 0.1% generics but they seemed generally pretty close to begin with). LEDs were also very closely matched but i found that i got much better results with LEDs which were not matched to each other. I don't know why.
I didn't understand how to match the transistors. The NPNs all gave me rougly 11.6v some swinging out to 11.9 and some as low as 11.4. This was apparently just as expected and i noticed that the the higher LEDs measured higher using the hFE measure on my DMM. The PNPs however were strange. FOllowing the diagram they all gave me 2.4 - 2.7v instead of the 5-6 that kevin said they should measure.
Anyway i can allways pull them off and remeasure. THe main problem i'm still having regards how to match them. The PNPs and NPNs give different voltage measures and have different hFE measures too. So how do i match them?
What i ended up doing was grouping all the transistors with similar hFE ratings together and grabbing the middle most set as this by all logic would mean they are pretty closely matched.
Anyway facts:
about -1vDC on right side,
about 1vDC on left side,
voltages swing all directions when LEDs are in place.
i'm lost for ideas
Any help would be greatly appreciated, i've been working on this amp for a good 3 months now in the RnD and i can't wait to hear the final product.
Anyway facts:
i'm lost for ideas
