lucozade
- Jan 16, 2010
Well as you can see by picture there is no holes visible through the velvet, how do you remove the earpads ?
Sorry for the late reply.
Uh... the holes are not visible through the velvet... you have to look directly to the back side of the earpads...
To remove the earpads just put your fingers underneath the earpads and pull out gently until the plastic band of the earpads comes out of the cups frame.
What setup are you using with the GMP?
Have you read the PM I sent you about the mods?
Any question, shoot!
Well then it surprises me that you find the GMP 400 to have tight bass...
To my ears they sound fat and a bit flabby in the bass and a bit slow through all the FR with those stock earpads and unmodded.
They lack transparency in stock configuration because of the ridiculous damping and very lightweight enclosures.
If they already sound good to you, that's all that matters.
EDIT: I assume that you meant earpads and not earcups?...
What's the big secret re: the perforated earpads on the GMP 400? This is all very mysterious.
Nice review lucozade, thanks. Also, smart collection of headphones in my opinion.
Yes i did mean the earpads lol .
I have to disagree about there sound with the stock earpads , i find them to be similar in sound quality and sound signature as the Q701 in many ways especially the bass which is not at all flabby or fat ,there is a little more mid/upper bass than the Q701 but not a huge difference ,not compared them directly for speed of the bass but i have no complaints and i would say they are a little faster than the hd650.
Transparency and resolution is also very good to my mind ,not quite as good as the Q701 in the upper treble in my opinion ,but than again they are half the price but i may well experiment with your modification at some point down the line![]()
