tmaxx123
- Dec 5, 2012
So unfortunate what’s occurring in this thread.... lh labs needs to step up.
@Audio Addict
Try this old trick:
1. Plug in the device, windows fails to load the driver.
2. Open up device manager.
3. Find the listing for the device (clearly marked with the dreaded yellow exclamation mark)
4 Right-Click and choose "Disable" (NOT Uninstall) The device will still be in the list but sort of grayed-out
5. Leave Device Manager open and unplug the device. (it will disappear from the list)
6. Plug the device back in. It will re-appear but still disabled.
7. Right click on it and choose "Enable"
Lol !!
Hey Mickey and thanks for your reply! Currently, I'm using USB Audio Player Pro and it recognized my V2+ with no problem. I will check the bit perfect in the software to see if this helps and will update you!!Test trial mode if works. Purchase it in Playstore. Can access built-in DAC or in otg. Forgot if works on your unit, but please try. Check bitperfect on app settings.
http://www.extreamsd.com/index.php/uapp-trial
I got it to work by disconnecting the Revive and plugging it straight into the Onkyo. Another question I have is, if the Revive worked between the V2+/Onkyo player and works between my desktop/Pulse; why wouldn't it not work between my amp/Onkyo player?Test trial mode if works. Purchase it in Playstore. Can access built-in DAC or in otg. Forgot if works on your unit, but please try. Check bitperfect on app settings.
I will play around with those tweaks to see what happens with it.... Thanks Mickey!!Android is still a hit or miss. It might work on one but miss on the other.
Bitperfect is for SQ (like it very much). If you want about connectivity please try/experiment usb tweaks on usb settings.
Dude! How about while trying to get my Revive recognized through the UAPP, my freakin' single ended connection on my Pulse is frying my ear like bacon in a pan! I just can't get a break!!! I tried swapping cables, different adapters and troubleshooting static problems. Just at a loss now and pissed, lol.No problem Bro.
I use an Android TV (Himedia Q10Pro) w/ built in HDD (WD Red 8Tb) -> Revive -> Geek Pulse as seen in my sig via UAPP as app.
So in my case Revive/Geek Pulse works w/ Android.
In your case I think there might be a problem w/ UAPP. Since they incorporated the HiRes Driver (for built in DAC), it might have problem distinguishing both (on the settings.>usb audio tweaks check "Use USB DAC").
How about:
1. Disinstall and reinstall UAPP w/ Geek Pulse + Revive attached
2. Try installing other software HibyMusic, Neutron MP if ti works.
