FS: Pro-Ject (Project) Head Box S Headphone Amplifier -Black
Status
Not open for further replies.
Type
For Sale
Currency
GBP
Price
85.00
post-10643567
Thread Starter
Post #1 of 1
stuzzyapple
£85 posted To Unted Kingdom
A must-have device for any fan of the can, the Pro-Ject Head Box S enables your headphones to perform to their very best. As new In original box tested and all working
A GREAT IMPROVEMENT IN SOUND FOR YOUR HEADPHONES
The Pro-Ject Head Box S isn't just for adding a headphone socket to an amplifier that doesn't have one; it's for adding to an amplifier that does have one! Such is the quality of a dedicated headphone amplifier such as this, that you should notice a marked improvement over your existing headphone output. The reason for this is down to the fact that it's dedicated to one purpose - driving headphones. The dedicated power supply can give a far greater current to your headphones than most built into amps. Greater current means a more dynamic sound with punchy bass. It's also more likely to get the best out of difficult to 'drive' low impedance headphones. Other quality improvements include a fully shielded metal case, quality volume control and gold-plated RCA connections.
DON'T LOSE OUT ON CONNECTIVITY
Connecting up the Headbox S is easy. Simply connect up to your amp via RCA phono outputs. As the Head Box S also has a set of RCA outputs you can easily loop through to the original source output - usually a recorder - meaning no loss of your amplifier's original connectivity.
Enabling a new level of detail and dynamism from your headphones, the Pro-Ject Head Box S is an essential addition.
Status
