jvos213
- Jul 4, 2014
Background
The first thing I did when I got the X5 3rd Gen in 2018 was to install two large micro sd cards to hold all my lossless music... from that moment on my player became EXCRUCIATINGLY slow. Literally everything related to the UI became unusable - opening folders, scrolling anything, clicking on any menu item etc. After multiple tries over the last few years of reinstalling firmware, upgrading cards and following forum tips by removing 3rd party apps etc, nothing really worked and its just become that player which I hate and lives in a drawer.
Until today!
With no real plan and while looking online at the M11 (some complain of the same laggy UI behaviour), I fired up the x5 III again today and it was painfully slow as usual. No surprise. I started messing around in the settings and did something which by total fluke 100% fixed it. It is now quite unbelievably super snappy with zero lag and it plays better than it ever has! 'Overjoyed' would be an understatement!
A warning - this method (if it works for you) will completely remove/uninstall and disable the Fiio Music app as well as the 'Pure Music Mode' option.
With regards to the Fiio Music app - I always knew it was running in the background hogging resources, but had no idea to what extent.
So here we go...
Method:
Some background info:
I personally use the unlocked PowerAmp player and it now works super fast, even with all album art and most files being FLAC. I suspect the same would apply to other third party player as well, but just in case - know that Poweramp works like a dream.
When I did this, my Android SETTINGS menu already had 'DEVELOPER OPTIONS' activated. Not sure if it was relevant, but it might have been. To enable this option:
Restart your device and fire up your favourite third party player with next to zero UI issues.
Be sure to keep the mode in 'Android Mode'.
If you accidentally selected 'Pure Music Mode', it will look just like the Android interface, but your third party apps will not open.
Keep in mind I did this today for the first time, so its not a try and tested method, so I really hope this helps someone else and if it does (or if it does not), please be sure to comment below to let others know.
Worst case - if it does not work for you, reinstall the firmware as no rooting is required to perform this procedure and reinstalling the latest firmware can be done by following the steps on the Fiio Website.
With that - I am off to enjoy what is essentially a new player!
Until today!
So here we go...
Method:
- I use 2x SanDisk Extreme 400GB microSDXC Memory Cards
- Android Version 5.1.1
- Kernel Version 3.0.101+
- Build Number 1.2.5
- NOT rooted - the device is factory standard.
- Go to "Settings", then tap "About device"
- Scroll down, then tap "Build number" seven times.
- In android mode go to the settings menu.
- In the settings menu scroll all the way down to 'About Device'
- Where it says 'Kernel Version' I simply tapped it repeatedly until I started getting the warning that FiiO Music will be uninstalled. So I kept tapping until it did exactly that.
