Fostex x Massdrop TH-X00 Review
post-13041975
Post #9,076 of 11,823
hung031086
Madison, WI
Madison, WI
Well the omni pads are out of stock right now :frowning2:.
Anyone tried these pads yet ?
http://dekoniaudio.com/product/dekoni-audio-fostex-th900-elite-sheepskin-replacement-memory-foam-ear-pad-set/
post-13042353
Post #9,077 of 11,823
claud W
Raleigh, NC
Raleigh, NC
Great headphones to listen to my putter system while I surf. The Wywires Red cable helps too. Silly me, I have no desire to change the pads. Plenty of well defined bass for me. Must be the cable.
post-13042652
Post #9,078 of 11,823
fjrabon
I think most people are pretty happy with the stock pads sound wise, most pad swapping is for comfort reasons for certain ear shapes.
post-13042679
Post #9,079 of 11,823
AT Khan
Amen to that.
post-13042886
Post #9,080 of 11,823
Vonsid
I was concerned about the stock pads as the hole appears to be pretty tiny on the pictures, but somehow it perfectly fits my ears. The rear of my ear sometimes touches the pad, but i don't feel any discomfort or pain or hotness sensation due to that, even after long sessions. Excepted if you have ears notably bigger than average, i wouldn't be worried about that.
post-13042908
Post #9,081 of 11,823
inertianinja
The stock pads just barely didn't fit my ears, so I wasn't getting a very good seal.
I've cycled through a number of different pad types, and although people tend to go towards HUGE, THICK pads, I am more-and-more looking for options that are close to stock pads in depth.
I think I posted a few pages back, the MSR7 pads are working out great for me. They're a bit of a bitch to get on the plastic ring the first time, but they stretch out to be basically the same as the stock pads with a bigger opening, maybe a bit softer overall.
post-13044549
Post #9,082 of 11,823
chenjy9
I tried the one for TH-X00, not TH-900.
post-13044671
Post #9,083 of 11,823
Vonsid
Purpleheart are available again on MD too. I wonder if i should cancel my participation in the Mahoganies drop and enter this one. Anyone owned both of them and can make a quick comparison ? I prefer the Mahogany look, i've been able to hear them and i like them, the 50 $ extra for PH are a bit problematic but i guess i could add them if the sound is significantly improved.
post-13044856
Post #9,086 of 11,823
chenjy9
Could always just buy Mahogany cups from E-Mu. Their cups look better quality anyways.
post-13045655
Post #9,087 of 11,823
Vonsid
Yes, but from what i've read, they might be reluctant to sell cups if you didn't buy E-MU headphones.
post-13045705
Post #9,088 of 11,823
mdoxey73
I own both and have compared them quite a bit out of the same source and amplifier chain. The differences are subtle, but ultimately I went back to the mahoganies because of slightly improved perceived mid performance (probably a result of a slight reduction in treble energy). I'm eagerly awaiting the ebonies before I decide which two to keep (one for home, one for office).
Reactions: Vonsid
post-13045724
Post #9,089 of 11,823
Vonsid
Thanks for your input :) How does the bass compares on the two headphones ?
Edit : nevermind ! I saw your detailed post here http://www.head-fi.org/t/788776/fostex-x-massdrop-th-x00-review/8550#post_12858753
That was completely the type of advice i was looking for :) I'm not a great expert in sound and i'm not sure i would be able to distinguish a subtle difference. Also, i like the look of the Mahogany better, and they are 50 bucks cheaper, so i'm probably going to go for them if there's not a major difference, specially in bass.
post-13045798
Post #9,090 of 11,823
fjrabon
Lately my EMU ebony cup THX00 with Lawton damping have been reminding me a lot of a HD650 with more sub bass. This is with the stock earpads. Same powerful, smooth midbass. Same notch at 2.5kHz. Same slight bump at 10kHz. Same liquids smooth mids (albeit about 3dB less mids than the HD650) Basically sounds like an HD650 with an amp with bass boost turned on. The Torpedo III really makes the bass kick like a mule, without losing definition at all.
Normally I don't love tubes in the chain for the THX00, but the iDAC6 (tube DAC) and Torpedo III are keeping it smooth, yet powerful and neutral. Really letting the THX00 shine.
Changing back to the stock earpads was truly like coming home with these headphones. Even though I prefer the stock earpads to the Lawton pads, the Lawton internal damping is a 100% improvement with no tradeoff.
Can't wait for the people who got the THX00 ebony to get theirs, because my emu ebony cups are a subtle, but to my ears, very marked improvement over the purpleheart and mahogany.
