Fostex x Massdrop TH-X00 Review
post-12946496
Post #8,926 of 11,823
m8o
Perhaps it would negate confusion if we start calling the one sewn to the stock pad the "earpad back plate" or "earpad sound-focusing plate" and the other the "mounting ring".
Notable differece, plate vs. ring.
post-12947628
Post #8,927 of 11,823
Ra97oR
CanJam London 2016 Karting Champion
How is everyone's luck with the polishing kit?
It solved the general glossyness and the bubble wrap mark. But didn't help with the hole and dimples with the lacquer on my Purpleheart.
post-12947704
Post #8,928 of 11,823
KewlMunky
Even after electing to return my Purple Hearts, Massdrop sent me a polishing kit. I guess it will be good to hang on to in the event I need it for the Ebony drop. If not, I'll probably send it out to a fellow user in need.
post-12948107
Post #8,929 of 11,823
crazychile
Yeah, it doesnt remove orange peel and they dont give you enough to do a proper job.
post-12948400
Post #8,930 of 11,823
innaterebel
Yea, since the mounting ring is what people will see at first sight when taking off the pads that is a ring and being plastic, and the inner plate is unique enough a design to be aware of, people not in the know naturally refer to the mounting ring when we say either "ring" or "plastic".
Yea, pretty much one redundant rubbish post I am making I know. Just want to thank @m8o for the head up
post-12948490
Post #8,931 of 11,823
Eudis
Pad attenuating ring.
Pad mounting ring.
People need to keep in mind that the pad ear hole shape/size/pad height/ pad angle play a role in the sound too. There's a measurable different between thx00 pads and Denon D2k pad.
post-12962535
Post #8,932 of 11,823
AOARoses
Canada
Canada
I found the stock pads on the PH very comfy after owning them for 3 months. I also found that I did not like the sound signature as much as cheaper headphones like Focal Spirit Pro which is sad considering the gorgeous look of the THX00 PH. I wish PH has more emotional mids and bass at the properly sealed region like 30hz to 50hz.
post-12968374
Post #8,933 of 11,823
NewbieSteve
I found the stock pads too stiff and hurt after 1-2 hours. While it wasn't bad, I do want to wear them for longer periods. While the alpha pads seem to be the way to go on this thread, zmf omni pads seem to be preferred on the EMU thread. So I ordered both and will be doing a comparison soon!
post-12968381
Post #8,934 of 11,823
AT Khan
Hahaha I like the idea you guinea piggin for the rest of us... hehhehe!!! Do tell us how that goes. We'll decide then.
Reactions: WayTooCrazy
post-12968595
Post #8,935 of 11,823
NewbieSteve
My wallet hurts... I did try the HM5 leather pads before this but they killed the sound for me. The mids got more recessed and it sounded boxed in. Hoping the alpha or omni pads will be closer to stock :')
post-12968613
Post #8,936 of 11,823
WayTooCrazy
Waterbury, Ct.
Waterbury, Ct.
Granted, I haven't used these headphones much (or headphones in general much), but what is the problem with the stock pads? They seem comfy enough for me. I do not listen more than 35-40 minutes at a clip though, so that could be part of it.
post-12968656
Post #8,937 of 11,823
MWSVette
Orlando, FL
Orlando, FL
For me the problem with the stock pads are that the ear hole is a little small and I found the pads to be a little hard.
I prefer the Alpha or TH-900 pads.
Of course IMHO, YMMV, yada yada yada...
Reactions: NewbieSteve
post-12968671
Post #8,938 of 11,823
AT Khan
The TH900 pads are indeed more room. Do they make the sound less focused, or reduce bass or affect stage or stuff in any way? Always been curious. Will need a replacement when my stocks die.
The Hm5 leather angled ones are a downgrade IMO.
post-12968780
Post #8,939 of 11,823
jeffri
Indonesia
Indonesia
Website
jeffri.me
I have TH900, Alpha and Omni Pads. In my experience:
TH900 pads - thinner sounding, more airy and wider soundstage I think, a bit prone to sibilance, but bass has more low end rumble. More v-shaped but still sounds pretty good overall.
Alpha pads - YMMV, but I don't like the sound with this. It was an old pads I used with my K551 that I enjoy a lot, however sounds kinda rough with TH-X00 for some reason.
Omni pads - tamed the high end a bit, I think a slightly bigger soundstage and smoother sound overall. Sounds not much different than the default pads, but a bit more refined. Won't suit those looking for treble I think.
Of course, again YMMV :)
post-12968844
Post #8,940 of 11,823
AT Khan
Hmmm... so do you recommend TH900 pads over stock? And what do you mean THINNER SOUNDING? So treble and rumble BOTH?
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
