Eudis
- Sep 6, 2014
Same happens when I cover the bass ports on my Thunderpants, which is why some of the various T50RP mods have cups with more ports on them (more bass and soundstage, I'd think). But a direct comparison to those cans sitting on a wood headphone stand with the cups completely sealed (as they would be on my head) yields very little sound leakage, even leaving the ports uncovered, whereas the PH's... well, they just don't isolate. You can hear everything! Granted, the drivers are completely different, but other closed headphones I own seal the sound far better than the PH's. I don't know how much difference the O-rings will make, but I can see a pretty good gap between the wood and the frame on my set, and I have to imagine this is where much of the sound is leaking from. Will update when I get around to it, hopefully this next week!
Tried it on my mods using bluetak, theres more to leakage/low isolation than just the side vents. The way the pads mount attribute to it as well.
