Fostex x Massdrop TH-X00 Review
Discussion in 'Headphones (full-size)' started by jude, Nov 24, 2015.
560 561 562 563 564 565 566 567 568 569
571 572 573 574 575 576 577 578 579 580
  1. andyDiamond
    Right you are
    Anticeptic wood varnish was used to preserve wood from catching flew and any additional humidity
  2. drwlf
    Lovely looking cups. Can't help of thinking some sort of an innuendo here :p
  3. HungryPanda
    took my purplehearts off tonight and the left earcup is spinning, the pin hat holds it is standing proud. I have been very careful with them too.
  4. WayTooCrazy
    Can you push them back down?
  5. MWSVette
    Received my Schiit Jotunheim last Friday and have been working my way through my different headphones finally tonight getting to my TH-X00.
    I am using my Bimby to feed the Jotunheim.
    I have enjoyed these cans since I got them.  But today was the first time I have used them through a balanced amp.  And all I can say is WOW.  This is the best combo I have found yet for these headphones.
  6. drwlf
    Phones reterminated as balanced?
  7. MWSVette
  8. drwlf
    Lovely!
  9. goody
    guys quick question what good adapter do you recommend for using with iphone
  10. HungryPanda
    I did and the screw that holds it is showing, not good it has happened with less than three weeks of use. I have contacted Massdrop support.
  11. innaterebel
    Search this thread, Sennheiser and Grado's had been recommended a load of times with rationale and links.
  12. VRacer-111
    So is the screw loose...should be able to tighten it to bring down the boss and get it back to how it should be. It will require taking off the cup and driver from the frame to do so, but it's easy if you are careful.
    HungryPanda likes this.
  13. HungryPanda
    I will see what massdrop say first so I do not lose my warranty. If they ok it I will.
  14. FaezFarhan
    Mine has finally arrived. Luckily with minimal bubble wrap marks.. #00524 here :)
  15. tradyblix
    I'm a bit surprised we don't have frequency graphs showing the difference in response between PH and PHBW variants at this point :) Adds a certain... pop to the midrange ? heheh [​IMG]
