Eudis
- Sep 6, 2014
The Elise is rated for 32 to 600 ohm HPs - but Lucasz (The guy who makes them) said it would also work fine with the 25z Fostex. Have even heard of people using it with IEMs. I do get a background hum when no music playing and volume WAY louder than I would subject my ears to, not sure if a higher z can or just more hours on the tubes will "fix" that or not. Will have some slightly higher z, lower efficiency HPs very soon to test with. As long as it can get them to "too loud" with no hum I'll be satisfied.
Funny you mention the m9xx. I was considering selling it and getting a DAC only, as it seems a bit of a waste not using the amp in that unit, I guess there will still be times where a little SS amp could be handy to have, and it certainly is a very competent DAC.
The elise also has an ouput impedence of 100ohm, does it not?
