elvergun
- Jul 15, 2004
I got my THX00 one day ahead of schedule, so I will not the the last one to get the headphone in the US.
My first impression (really quick since I was on my way out, only half a song) was that the D2000 is better. My impressions mirrored those of MattTCG, specifically when it came to the bass. I thought it was a little lose and boomy. The soundstage was narrower when compared to the D2000. Something was just off.
When I came back, the first thing I did (before even having another listen) was to replace the pads with those I was using with the D2000 (pleather HM5 pads). Wow, what a difference. The boom is gone, and the soundstage is now much wider. I then put the THX00 pads on the D2000 and the bass was increased on the Denon and it sounded a little flabby. Also, the soundstage became constricted...and something was just off. For my tastes, the stock pads suck big time. The HM5 pads are also more comfortable; there is room in there for huge ears.
I'm going to order another set of pads HM5 for the Fostex ASAP.
The THX00 is B-E-A-U-T-I-F-U-L. It sounds at least as good as the D5000 and the D2000 -- you can tell they are all siblings. I was thinking about purchasing a TH600 when Massdrop released this model. The THX00 is cheaper and better looking. I am a happy camper.
Here are some pictures with the HM5 pads:
