Fostex x Massdrop TH-X00 Review
post-12143125
Post #1,921 of 11,823
fjrabon
post-12143213
Post #1,923 of 11,823
aak57
Is there a guide for replacing the cable with an SMC setup?  From some research all I could really find are pictures of headphones after the mod and that these are apparently the connectors I should get.  But looking at them I'm not sure how soldering would work, and I'm also enough of a newb I don't know what cable I should buy to go with them.
Reactions: legcramp
post-12143232
Post #1,924 of 11,823
Sonido
I don't think it's a known issue yet, but it is something to be cautious about. And since I think it's safe to say they'll be current hungry anyway, you probably want a low output impedance amp anyway. Plus the Vali won't remotely help a can that might be in danger of flabby bass already. You put the Vali in front of a can with overly strident bass if anything.
Excuse my novice question, but how do you know if a headphone needs current over voltage? Is it based on a combination of the sensitivity and impedance? And I agree these (or at least the TH900) sound good with more current. Especially can hear a difference through the current output of my Bakoon amp.
post-12143255
Post #1,925 of 11,823
JohnYang
A good rule of thumb is usually lower impedance headphones want better current control, while higher impedance headphones want better voltage control.
But it is sometime case by case situation.
This is at least what I learned, could be wrong.
post-12143390
Post #1,926 of 11,823
nicolo
Apparently offended people with my comments as they're being considered sexual objectification and thus not amusing. So removing these just in case.
Moderators: please remove all other instances of my comments in other people's comments and as they're not germane to the discussion here anyway. Thanks.
Further i will refrain making comments anyone may find offensive on this forum going forward.
post-12143404
Post #1,927 of 11,823
vwinter
In respect of wishes.
post-12143421
Post #1,929 of 11,823
MannerPylon
If only things were so simple... the coded wording in those descriptions...
In hopes that this thread can continue on without raging fires let's turn our attention back to the HPs themselves.
I'm eager to hear people's impressions as they come in. Going to start experimenting with different amps for these to see how easy/hard to drive they sound or how sensitive they are to pairings.
post-12143468
Post #1,930 of 11,823
Billheiser
Maybe start a thread for fu date, marry, kill?
E.g., I'd date the LCD-3, marry the TH-X00, and kill the Grado Rs1e.
post-12143481
Post #1,931 of 11,823
nicolo
I dated the LCD-X, married the HE-560, killed the Grado 325i
post-12143492
Post #1,933 of 11,823
Soundsgoodtome
SEATTLE
SEATTLE
Reactions: moedawg140
post-12143495
Post #1,934 of 11,823
MannerPylon
Code! What code? Please explain:wink:
Don't think it was your intention but using adjectives like "perfectly" and "skinny" have positive/negative connotations that are less descriptive and more geared to sway a reader in one direction or another.
post-12143509
Post #1,935 of 11,823
nicolo
Corrected that. Good catch. Wasn't intended as you said.
