Fostex TH900 vibration problem [NZ]
Oct 10, 2017 at 6:40 AM Thread Starter Post #1 of 1
Grom8
Hi all,
I own a pair of TH900s which are awesome but they have a vibration problem in the right driver. Noticeable with low/bass sounds, I can hear the vibration of the right driver like its hitting the walls of its enclosure or something. Its hard to explain but it defiantly isnt supposed to be happening, im not sure if its because something is loose or the driver is broken, everything else is fine and again only noticeable during low sounds and bass.
Also I'm located in NZ which is a pain because Fostex points me to the closest retailers of their products in Australia, I dont really want to send them overseas, its a hassle. I'm hoping someone may have info on where I could get this problem looked at if there isnt a fix I can do myself.
Thanks for reading :)
