Afghan Vet
- Dec 17, 2012
Here's a video that shows you how to remove the pads:
https://www.youtube.com/watch?v=BjOr2kcQJDk
For the carbon pads, the leather will be loose. Grab the loose leather, instead of the foam stuffing when you are twisting the pads in and out of the slots.
I watched the video. The Dekoni pads seem to freely spin around I'm afraid I'm going to break something if I push harder and turn. I took the stock ones (see photo) and put them next to my ear and with my ear size they're going to rest on my ears and likely be uncomfortable. My first adventure into better headphones was with the Grado SR-80. I just have a feeling putting those pads on the TH-900 will have the comfort level of a Grado headphone and that's not saying much. I have the EQ to ramp up the bass and overall it's pretty decent like that.
I threw those in right before I closed the box, almost as an afterthought. That was how they fit on my ears....kind of resting on the ear instead of something that rests on the side of the head - around the ear. I got used to it, and was comfortable for me - but those who put them on for a demo typically mentioned the way they felt. If you want to take off the Dekoni pads - you could probably 'peel' off the leather from the plastic ring that connects them to the headphones, then twist and disconnect the white plastic ring.
