Fostex TH600 Dynamic Headphones
Jul 18, 2015 at 9:20 AM Post #2,791 of 3,435
L1C4
Aka: Craig Olsen, olsonc84, Craig Olson, olsonc84, craigjolson and numerous other names
Undeclared Member of the Trade: Berkeley Bulldog Audio
I've owned them all, and actually, multiple pairs of each. Most of the added cost for the Fostex are the Japanese Cherry Birch housings with traditional "Urushi" lacquer.
I will agree that both the TH600/900 sound more 'fun' than the D7000, but that doesn't translate to accuracy.
Fostex obviously thought they could go out big with their prices, but TH900 retail is now $1,299.99 and the TH600 is $599.99 so your price comparisons are a bit off. Money also doesn't translate to better sound -- obviously, money can buy better R&D and good materials, but if you have a bad design or bad production, it doesn't matter.
Jul 18, 2015 at 9:25 AM Post #2,792 of 3,435
ati832
I did not know this was a thread to argue on it's a thread to post your thoughts on th600's if you want to attack me then please do it via pm thanks, no need to get angry posting.
Jul 18, 2015 at 1:07 PM Post #2,793 of 3,435
Oregonian
Oregon
It's all subjective in audio as we know - but my experience owning both Fostex units, a D7000 (now a LA7000), two D5000's and two D2000's was that aside from the D2000 being a notch down (not far down mind you), the other four were close enough to each other that unless you have great ears (which I don't) you will be more than happy with a D5000 or a D7000 if you want the improved cup finish over the Fostex.
That all said - I know many of you have great ears and can hear the difference from a TH900 to a D7000 but to me the cost differential was not worth it - not at all.
My real point is - I love them all!  That Fostex/Denon sound is my favorite signature ever.
Kind of glad I don't have golden ears!
Jul 20, 2015 at 2:33 PM Post #2,794 of 3,435
Max Choiral
What do you mean by "subjective"? The difference between TH900 & D7000 is as night and day. You don't need to have golden ears to hear that
Jul 20, 2015 at 3:47 PM Post #2,795 of 3,435
Oregonian
Oregon
That's YOUR opinion.  I had them both. Side by side.  Didn't hear the night and day difference at all.
Jul 21, 2015 at 12:42 PM Post #2,796 of 3,435
Max Choiral
ok-ok, no offence. No need to be angry
Jul 21, 2015 at 12:55 PM Post #2,797 of 3,435
Luckbad
Irvine, CA
  If you can find a second hand ALO Pan-Am, since they have been discontinued, that sounds very good with the TH-600 as well.
Started searching for the PanAm. Hopefully I'll find one at a reasonable price at some point.
I contacted Little Dot and they did not recommend the MkIII or MkIV for the TH600 due to the OTL design and low impedance of the headphones. They recommended the I+ as the cheap option, then the Mk9 and Mk6+ as the best options (I believe both are OCL). Unfortunately, the Mk9 and Mk6+ are well beyond what I'm willing to spend on a headphone amp.
I'm also poking around at the Project Ember. Minimum impedance listed is 32 Ohm, so I'm going to ping them and see what they recommend.
Thanks all!
Jul 21, 2015 at 7:45 PM Post #2,798 of 3,435
DavidA
Hawaii
Thanks all!
The Ember works quite well with the TH-600, its my favorite amp for them, I also have a Lyr2, Asgard2, Modi, BH Crack and Teac UD-301 and AH-01 to compare with.  The adjustable output resistance/impedance of the Ember lets it pair with a wide range of headphones from planars to Senn HD-6XX.
Jul 21, 2015 at 7:56 PM Post #2,799 of 3,435
Nilisco
I ended up emailing fostex after all the conflicting info on what happened.
In summary:
The th-600 was discontinued but will eventually be replaced with something in a similar price range. The timing for this was unknown by the CSR, but I doubt it'll be soon. Really wish I would have got in on the B&H photo deal at 450$.
Jul 21, 2015 at 10:31 PM Post #2,800 of 3,435
Luckbad
Irvine, CA
Thanks! Any recommended tubes for a basshead? I will use the amp at work and listen to a lot of ambient bass and liquid dubstep because it isn't distracting.
Jul 21, 2015 at 10:43 PM Post #2,801 of 3,435
DavidA
Hawaii
Getting great sound with 12AU7 Telefunken and 12AT7 Bugle Boy.  Also just started using some 6SN7 but you will need the adapter so the cost goes up and IMO the 12XXX tubes work quite well
Jul 21, 2015 at 11:05 PM Post #2,802 of 3,435
roguepp88
Thanks all!
Good luck, the minimal impedance for the Pan-Am is 32 Ohm as well,
which is just alright for the TH600.
There see that discounts around for brand new Pan-Am's since they are trying to clear the left overs I think.
A new one may also be coming out in the near future,
but I have no idea about that.
Jul 23, 2015 at 10:03 AM Post #2,803 of 3,435
obsidyen
Cambridge, UK
In summary:
I hope they make a new HP with smoother highs, a bit more mids but still *** kicking bass! I'd totally buy that.
Jul 23, 2015 at 10:07 AM Post #2,804 of 3,435
manbear
You dont have problems with noise floor?
I used to own an Ember but got rid of it because it was too noisy with low impedance headphones. But i agree that its a good amp otherwise.
Jul 23, 2015 at 10:19 AM Post #2,805 of 3,435
DaemonSire
I found this very dependent on the tubes.  I have a Solstice (very similar to Ember), and on some tubes, it is very noisy and on others, quiet.  I found changing the output resistance from low to medium would quiet them down a lot as well.
Right now, I have a pair of Grado 325e going into my Solstice with a medium output resistance and it is very quiet.  But as I mentioned, a couple of my tubes are quite noisy so it may just take some experimenting.
