SonyFan121
AKA Steven31, Audio Aficionado, Audioholic123, JVC steven, and others
Thanks for your answer.
Yeah, I already have.
I have played with the screws a little bit, but it doesn't change anything. I even took one of the driver out because I thought that the wood earcup might cause the issue, but nope, I still get the problem.
However covering the hole behind the driver almost totally fixes the issue. (This hole here, it's not my picture though : https://i.gyazo.com/8200d806f6a2b2dd394a05bb34feea7b.png )
But then obviously it sounds awful in the bass area since it's sealed and there is no longer air going through.
So whatever this issue is, it's from the driver itself.
But from what I've seen the issue might be this : a warped diaphragm. https://www.head-fi.org/threads/fos...nd-measurements.618659/page-132#post-12124146
I would take the driver appart to try to fix the issue myself but since it's still covered by the warranty I don't want to mess with it for now.
Now I'm trying to find a way to contact Fostex but I'm not even sure this is possible. On their website they say that you have to directly contact the distributor where you bought the headphones from...
Huh, If I had knew, I would have never bought this damn thing. This is so frustrating.
Sorry to hear about this, I hope you can get the issue sorted.
