nax0rz
- Dec 9, 2013
Hey guys I got myself a T40RP MK3 on sale at my local AV place. I have a gift card I plan to use for some replacement ear pads but not sure which to get. I was wondering if anyone can confirm if any of these would fit or not.
Beyerdynamic EDT 770 S
Beyerdynamic EDT 990 VB
Audio Technica HP-EP M-Series
Shure HPAEC440
Shure HPAEC840
Shure HPAEC240
I know there are plenty of other options, maybe better than these but those are my only options. Any comments on which you suggest would be appreciated.
Thanks!
The 840 pads fit, I'd assume that the other shure ones do as well. No idea about the other ones. I'd highly suggest taking a look at ZMF pads which are made for the t50rp, they're worth the price IMO.
On another note, I was hoping someone could help me out with my modded t50rp's. I'm using ZMF lambskin pads, I've filled the baffle holes with newplast and added silverstone foam to the bottom of the cups. I'm really liking everything right now except the sibilance is just a little too much. It's not a painful amount but its definitely creating a slight discomfort in my ears. What can I do to fix this?
