Fostex HP-A4BL (the A4 with balanced output)
post-15080103
Post #331 of 345
aqtaket
Another quick question to the happy owners of this wonderful Fostex unit:
If I hook up a DAP vis USB OTG cable+ the Fostex USB cable supplied, will it supply power to the DAP (and charge it) from its USB 2.0 port, or this port is only meant for data transfer?
post-15080204
Post #332 of 345
HungryPanda
Kent, UK
Kent, UK
As far as I know the USB is only for connection to computer
post-15080373
Post #334 of 345
HungryPanda
Kent, UK
Kent, UK
I have never tried so cannot advise
post-15094239
Post #335 of 345
davehutch
Website
www.hutchinsonphotographic.com
Having an issue...
I bought an adaptor from Drop.com, the balanced XLR to 2.5mm, so that I could use my IEMS. However I get small electric shocks (tingles) from the metal shells of my IEMs.
Any idea what's going on? I have a multimeter and if I measure between the left and right shells, there's about 19V.
I should also add that I'm using optical in to the amp
Can anyone help please?
post-15098313
Post #336 of 345
aqtaket
Having an issue...
There are differenr pinouts for 2.5mm balanced. The so-called "European", "Asian", "Fiio", "AK"....
Looks like the pin-out of your adapter does not match the one of you male-jack in the phones..
post-15098551
Post #337 of 345
davehutch
Website
I also made my own adaptor cable and I get the same issue. Fostex distributor, SVC are assisting but there doesn't seem to be a pattern to it. If I measure between pins 1 and 3 I get 1 or 2 millivolts, which is fine.
Same between pins 2 and 4
Yesterday I plugged in and for a while it was all fine, but then I started getting shocks again.
Can anyone else with metal bodies IEMs let me know if they experience the same issue?
post-15102427
Post #338 of 345
aqtaket
This Fostex has only one DAC chip, but a balanced amplification part, is that correct?
If so, that seems a bit strange to me, a balanced DAC/amp should have two DACs and two amps for true balance. What Gives balanced output in this case? Only higher power?
post-15162975
Post #340 of 345
dsnedeco
Florida
Florida
Can someone explain to me exactly how to uninstall the HP-A4 usb driver and install the HP-A4BL usb driver on Windos 10. I have been unable to do that. I have downloaded "FOSTEX_USB_Audio_Driver_V221.zip" It seems like no matter what I do I end up with the HP-A4. It works OK but it is not the HP-A4BL. Some where along the line months ago I had it installed. But then my computer crashed and I can't seem to get it back.
post-15164313
Post #341 of 345
davehutch
Website
*Update*
Fostex sent me an earthed power supply. All is now fine :)
post-15164316
Post #342 of 345
HungryPanda
Kent, UK
Kent, UK
Glad to know all is fine
post-15298336
Post #343 of 345
gimmeheadroom
Czech Republic
Czech Republic
post-15339263
Post #344 of 345
RSC08
Anyone tried this amp with the Hifiman Sundara? I'm looking to upgrade my home setup and currently deciding if I should go HP-A4 + Sennheiser HD650 or Hifiman Sundara.
post-15339324
Post #345 of 345
gimmeheadroom
Czech Republic
Czech Republic
Sennheiser 600 series are at their best with a tube amp. The Fostex would not be my choice for Sennheisers. I have no idea about the Sundara.
