SeraphicWings
- Dec 24, 2016
So Apple switch to APFS file system in iOS 10.3 from HFS+, which may have resulted in a bug on USB Audio data transfer for Mfi certified USB DAC and CCK-DAC
However, I've found a solution that could possibly permanently fix this issue:
1. Install iOS 11 Beta (Preferably beta 1 since there is an issue with downgrading beta 2 to 10.3.2)
2. Download an app called 3uTools for your PC (This is a multi-purpose app including flashing iOS firmwares)
3. Use 3uTools to downgrade from 11 to 10.3.2 (REMEMBER TO TICK RETAIN USER'S DATA WHILE FLASHING - this is extremely important)
Explanation: In 11 Apple apparently has patched this issue (as reported by some users including me in head-fi), this method allows you to downgrade from the unstable iOS 11 to the more stable 10.3.2 while KEEPING THAT PATCH and transfer it to 10.3.2, which will solve the USB Audio issue
Let me know if you guys have tried it and whether it fixed the problem or not!
