Scutey
The 6BL7sounds very good with either EL3N or EL11in my Elise so I can only imagine how they sound in your Glenn.6BL7 sounds good and they are great on Glenn's OTL amp.
Thanks I will!, two sound pretty good so my next step will be try a quad.wow now that's a deal I really enjoy the 6bl7's in quad their an excellent sounding tube for cheap..enjoy
Can someone verify in my WA22 does the 6BL7 go into the 6080 or 6SN7 slots? Sorry for the newb question. Still getting acquainted with the tube world and trying not to screw something up here.
Yip. Straight in.
Straight in as a replacement for 6080 or for 6SN7? Thanks in advance for the clarification.
Use the 6BL7 as a replacement for the 6080. It's a power tube. With the appropriate adapter, you can use dual 6BL7 into a single 6080 slot. There should be some pictures in this thread.
Power tube 6080 replacement. Don’t use as a driver 6SN7 tube.
You can throw in a single with no adapter. Dual needs an adapter.
Sorry, this won't solve the hum problem.Thanks guys. I look forward to trying it out. Might have to give the dual tubes into a single slot a try.
The WA22 supposed to be dead silent with any combination of tubes.
