adeadcrab
- Jan 30, 2008
cetron 7236 might be easier to get, and is apparently a better match for that amp
And they're both probably equal at gain, I take back the 5998 having more gain. Up to what your looking for in sound really. .cetron 7236 might be easier to get, and is apparently a better match for that amp
I definitely find the 7236 less "tubey", producing excellent detail retrieval, instrument separation and well-balanced frequency neutrality. In a warm-leaning system and with a warm driver tube this is an asset whereas can be less so with other gear.Mu around 5 would certainly be enough, it’s really just to drive the power amp a little more when I’m using my iPad or other low level sources. I’ve read that the 7236 is less "tubey" sounding than the other big twin triodes, is that correct?
That's correct, with a nice warm preamp like a Sylvania and you can get a nice pairing.Mu around 5 would certainly be enough, it’s really just to drive the power amp a little more when I’m using my iPad or other low level sources. I’ve read that the 7236 is less "tubey" sounding than the other big twin triodes, is that correct?
Did you ever get this going? If not ship that baby over here to me, I'll fix it for ya.So the tube worked in both channels for one session. Next time I powered up the amp (without touching the tube at all let alone removing it) the left channel had completely cut out again... Tried the solder trick today with 30 seconds on each pin plus adding a bit of extra solder to the tip. No luck! Still only one channel. I took the tube out and gave it a dozen good whacks against my mouse pad. Tried it again and voila, both channels are working again! Very strange - I guess I'll just keep whacking it...
The guy posted ahead of you is going to be a dealer soon. LOLBold added by me. This reads like it was put together by Western Electric's sales and advertising group. To imply that all one has to do is to pull out an inferior low power 6SN7GT and swap in a more powerful WE421A (or 5998 or 6AS7G) and everything will be better is hogwash. lol
Edit: And I should add, Western Electric didn't make the 6SNGT. Rather, RCA developed it and owned all the patents.
Think we got ours from the same seller. Mine hasn't shipped yet. #anxiousI have one on the way.
Markings are nearly missing, but one can barely make out CHA. Needs a little TLC, but measures strong according to the seller.
