cddc
- Dec 7, 2009
Cool...I will see if my amp can take them. Thanks a lot!Try 6C8G. Basically the same as 6F8G but with more gain. Way cheaper also.
I have several different brands of the 6F8G and the 6C8G. IMHO the National Union sound the best.Yip. They can be cheap.
I purchased some beautiful Tung-Sol roundplates NIB for US$30.00 a pair.
They sounded exactly the same as the 6F8G at $150 a pair.
I also picked up a box of 100 RCA's 6C8G for $50.00. They sounded good as well.
Everything is possible but can’t remember seeing any from AU. US, British,Russian, Chinese and Japanese; yes.Is anyone aware of any 6AS7Gs or functional equivalents that were manufactured in Australia?
The amplification factor is 4.8 compared to 2 for a 6080 tube. Don't know if it makes much of a difference in terms of noise - it should just sound a little louder.Any knowledge of these two here in the forums? Just got the Sylvania 7236 here and seems like it might match up with the Tung Sol 7236, the latter (Tung- Sol) appears to have a higher amplification.
Thanks, it took my Tung Sol 7236 a few weeks to "open up" so maybe the same is required for the Sylvania 7236? i suspect that both are gonna sound more the same than different, with the Sylvania having a wider soundstage,The amplification factor is 4.8 compared to 2 for a 6080 tube. Don't know if it makes much of a difference in terms of noise - it should just sound a little louder.
If a 7236 tube is up to spec, it should have the same amplification no matter which brand.
Yes the Tung Sol on initial listen has the tighter control in vocals and bass, and somewhat faster, the only tube that the Sylvania sounded better with was the Black Treasure...it wasn't even close. Thanks for your input, I had written a little write up for another thread then decided to can it until the Sylvania was burned in. Might not matter, the Tung Sol has its reputation for a reason.I only have the Tung Sol 7236, but based on what I read, the TS is better sounding than the Sylvania. As always, the sound of a tube is amp dependent, and you have to let your ears be the judge.
Most tubes seem to need 30-50 hours to burn in, but some require much more time.
Sorry to open this thread years now... but I have the same felling.
Paid big money for 5998 ting sol, but I’m really disappointed. To lean and bright with hd800
That's a bit surprising, one thing I've never found the Tung Sol 5998 to be is lean and bright, In my system the TS is warm, but not overly so, transparent, with good detail and deep, warm bass. If they are NOS it maybe that they need a few hours burn in.
I was using Beyerdynamic DT1990.Just curious: were you using HD650 or HD800 or other headphones with the 5998?
