kaiwei
- Aug 2, 2001
Actually you should choose 24bit padded to 32bit for the Revo with dither on (strong ATH). The data is still 24bit just padded to 32bit with zeros in order to let the processing go through. Even though your source is 16bit, 24bit padded to 32bit output is your best choice because fb2k internally already decodes at 64bit, you'll need to dither down to your soundcard output ANYWAY so choosing 24bit padded to 32bit is the best choice. Unless your soundcard can produce 32bit floating pt or 64 bit floating pt output which the Revo can't.
Rounding errors is why your should dither.
