PredCaliber
- Jan 20, 2015
I cant find a specific thread for this, but I was wondering if there were folks who have the Sound Blaster X7 external DAC/AMP paired with their sennheiser HD 650? And if so, are you using any specific settings for the HD650?
In example:
- Are you using ''direct mode?''
- For the gain setting , are you using the standard 32/300 ohm? or perhaps the 600 ohm?
- Are you using the equalizer?
I really have the Crystalizer set to max because that makes a huge difference for me, for the rest no fancy settings.
In example:
