Focal Utopia General Discussion
Discussion in 'High-end Audio Forum' started by Allanmarcus, Jun 14, 2016.
Has your utopia needed repair from your dealer or Focal, either under warranty or not?
  1. Yes
    23.9%
  2. No
    61.4%
  3. I prefer not to answer
    14.6%
690 691 692 693 694 695 696 697 698 699
701 702 703 704 705 706 707 708 709 710
  1. dontfeedphils
    When I made my own cable I just used mini 4-pin XLR connectors to connect different termination adapters to the main cable. Works great and I've got options ranging from full size XLR, 3.5 straight, 3.5 R/A, and 6.35.
  2. Focux
    Wow a Utopia owner from NZ,
    Do u get your gear from AVWorld or ListeningPost?
  3. silversurfer616
    The Utopia I got from Listening Post; couldn't resist.
    Focux likes this.
  4. Jozurr
    Has anyone heard any headphones that do microdetails better than the Utopias (excluding the HD800)?
  5. tekkster
    To my admittedly weak ears, the sr009 may be the most detailed i’ve ever heard. For some instruments, not all, possibly the most realistic sound i’ve ever heard
  6. up late
    can't say that i have, but that wasn't the only criterion for choosing the utopia over the hd800 and the sr009
  7. jlbrach
    susvara and abyss phi tc
  8. 506638
    Yes, PMx2
  9. silversurfer616
    Have the 009S, Utopia and HD800S and for me the 009S has the most detail and this in a very realistic and musical way. Going from 009S to Utopia is sort of shocking as the latter is then shouty and too bright. Not to mention the limited soundstage.
    tekkster likes this.
  10. MacedonianHero Contributor
    I'd add SR-009 to that list as well.
  11. TSAVJason
    I’m a bit conflicted .... which do you guys prefer between the 009 v 009S? I lean toward the 009S as it seems just a hair more full bodied. But then there are times the 009 floats my boat.
    The Source AV TSAVJason Stay updated on The Source AV at their sponsor page on Head-Fi.
    https://www.facebook.com./pages/The-Source-AV-Design-Group/153623164648713 http://www.twitter.com/TheSourceAV http://www.instagram.com/Thesourceavdesign http://thesourceav.com/ Products@TheSourceAV.com
  12. MacedonianHero Contributor
    While I haven't spent too much time with the 900S, I was fairly certain that I prefer the 900S as well. :)
  13. Joong
    I think that the sound production in good fidelity requires a sufficient level of spring mass to power ratio be very low , where electro stats comes first and then planars with thin membrane.
    Those dynamic phones have relatively higher ratio regardless of technologies where utopia has less dynamic mass of Berylium with coreless voice coil, the combined weight of which is still not comparable to the dynamic mass of thin membrane with thin-printed voice traces on it.
    This technical limitation is there, so that 009S superiority is easily understandable, even though light weight beryllium cone with floated support and coreless voice coil is regarded as big new way of design to overcome the traditional limitation of dynamic drivers.
    Ojisan and silversurfer616 like this.
  14. Zhanming057
    When driven well:
    - Susvara (treble and midrange detail)
    - 1266 Phi and Phi TC (bass and treble mostly)
    - Diana Phi's (more of a tossup, and they are picky about synergy when you're trying to max out resolution)
    - Mysphere 3 (midrange and treble)
    - Raal SR1a
    - Stax 007 and 009
    - Shangri-La, maybe Shangri-La Jr. but definitely the Sr.
    - Shure KSE1500/1200, they need a desktop amp mod to sound their best though.
    Joong likes this.
  15. Jozurr
    How would you rank these when it comes to detail? (specially treble and midrange detail?)
