baiyy1986
Don't forget stock cable cost 1000
Absolutely. If your power from the wall is really crappy, a power conditioner is probably a must. When I was at the Phoenix meet, one of my DAC had horrible static unless it was plugged into a power conditioner. I believe those are the exceptions, however, not the rule. As always, YMMV
Egads, that thing is $5000! Did you try a perfect sine wave UPS from cyberpower or APC first?The thing is, the P10 reads 1.8% THD coming out of my wall and the P10 regenerates it to .1%. I don't know if 1.8% is bad or about average. All I know is the Utopia I had went from good to amazing and I don't believe I have supersonic hearing. Noise is the enemy.
Are there any good aftermarket cables for Utopia that cost under $500?
What are you looking for? Shorter? Lighter? Balanced? Colors? Thickness? Different sound signature?Are there any good aftermarket cables for Utopia that cost under $500?
Gear can always be upgraded. Once you start, it's hard to stop. If you can be happy with what you have, you are happy.I am enjoying my pair for a few days now, and don't even have time to really listen to it, work and family , driving it with Audio GD R2R-11, and wondering: should I be concern upgrading my gear? Perhaps there is a soul here that went from R2R-11 and was wowed.
Yes, I've been chasing this audio Dragon for a while now, with small bursts of happiness and then back to the unsatisfactory level. lolGear can always be upgraded. Once you start, it's hard to stop. If you can be happy with what you have, you are happy.
If you are interested in upgrading, then I recommend you listen to other great at meet-ups and at dealers. You can also go to CanJams or other audio shows, but it's very hard to listen at those events.
If you upgrade, determine what it is you want from new gear, and what it is you don't like about what you have now. Other wise you are just chasing gear and you will never be happy. It's perfectly OK to say you just want to try new stuff, but there be monsters there!
