wldcohso
- Dec 20, 2015
I’ve heard good things about Lavricable Grand 20 cable. Personally I haven’t been able to test it out but many many good reviews.
Yeah I'm looking for a new cable more for comfort than anything else, but I want to make sure it will at least sound as good as the current cable. I think I will go with the Black Dragon Cable by Moon Audio for my Utopias in balanced operation. Thanks for the help.That's why I say you should test it out yourself. If you don't hear it, then you don't and you should stick with the heavy long stock cable. But from the Chord Dave and Hugo 2, it's a pretty substantial difference that I hear with my set of ears.
But I wasn't motivated to buy a 3rd party cable for sound improvements. It was just that the stock Utopia cable was that long and heavy, that for the first time in my life I felt the need to buy a 3rd party cable. And I wasn't disappointed also in terms of sonic improvements.
I have a set of Utopias incoming! Are there any "budget" (~$150 max) cable options? I just want something shorter/presumably less heavy than the stock cable...
TSAVJason
Stay updated on The Source AV at their sponsor profile on Head-Fi.
maybe it's just you? good to see that you're giving them a chance anyway. i think that they're an exceptional headphone.Listening to the Utopia today/tonight, and their actually really impressing me more and more.
They still sound smooth, but much clearer with more definition and detail, as well as sounding tighter and more precise than the other night when I listened to them for 3-1/2hrs. I wonder if it's due to them playing at room temperature compared to playing them from just arriving from the cold the first night?
It very well could be me.maybe it's just you? good to see that you're giving them a chance anyway. i think that they're an exceptional headphone.
I'll definitely look at Wireworld as an option. Thanks for the recommendation!Not to sway you from the dragon cable you’re thinking about, but If you’re looking for something comfortable and neutral (not modifying the sound of the package you bought) I’d like to suggest the Wireworld nano.
Looks pretty cool. Definitely fits the holiday season hahaBTW, here's my hybrid "Candy Cane" cable. The silver is cotton sleeved solid core 24AWG 4N silver wire. The red is 2 mogami 26AWG per channel copper.
The 4 red wires are braided together. The two silver wires and the red braid are themselves braided to the Y. Then two red wires per channel are wrapped around a silver wire to each connector. All sealed in clear heat shrink. The whole cable isn't all the flexible, but it's still OK for what it is.
Sorry if I already posted this here. I'm getting old and can't remember
Here is a screen shot of the settings I used for my Focal Utopias with Isotope Neutron 2. You can use just about any parametric EQ VST plugin you like. I have mine in JRiver Media Center.Would love to see settings
