chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
NewOntech dac7
Look into the new Flux Labs Mentor. It’s tuned to be more neutral than the other models in their line up and fits within your budget.Most of my amps are on the warmer leaning side, I'm looking for something that brings the resolving nature of the Utopias to its fullest extent.
What are some recommendations of a budget 1-2K? I'm thinking a hugo 2 may be the move
Hugo 2 with Cayin C9 is a great pairing for the U22. I take the U22 or the Abyss Diana MR on my trips with this setup.Most of my amps are on the warmer leaning side, I'm looking for something that brings the resolving nature of the Utopias to its fullest extent.
I would recommend a DAC change before diving into another ampMost of my amps are on the warmer leaning side, I'm looking for something that brings the resolving nature of the Utopias to its fullest extent.
IBasso D16, DAC/ AmpMost of my amps are on the warmer leaning side, I'm looking for something that brings the resolving nature of the Utopias to its fullest extent.
Hugo2 valid option for dac/amp or qutest for just a dac at a cheaper priceMost of my amps are on the warmer leaning side, I'm looking for something that brings the resolving nature of the Utopias to its fullest extent.
Is the qutest on the same level of dac as the Hugo 2?Hugo2 valid option for dac/amp or qutest for just a dac at a cheaper price
I feel like my current set up is that. V226 into a bifrost 2/64. The amp is warm leaning and it makes for a really pleasant listen. Or if I swap to my Cayin-HA3 I get a presentation very similar to the 2022 Utopia.Don’t think you will like Chord dacs with Utopia if you are looking to relax and not get listening fatigue.
They are the same DAC, but Hugo2 adds the extra functionality. Qutest also has the same filters and the ability to change its output voltage between 1V, 2V and 3V.Is the qutest on the same level of dac as the Hugo 2?
Agreed, my fatigue starts around 8 hour mark.Don’t think you will like Chord dacs with Utopia if you are looking to relax and not get listening fatigue.
People listen to the Utopia to relax?!Don’t think you will like Chord dacs with Utopia if you are looking to relax and not get listening fatigue.
Yes. Listening to Utopia 2022 is like sitting near field in front of small high end speakers. It’s quite musical, warm and relaxing. You won’t get there with Chord, dCS, MSB, Esoteric, or Bricasti.People listen to the Utopia to relax?!
You can listen to Utopia on Chord for 8hrs without EQ? What type of music, how loud do you typically listen at and how old are you if you don’t mind me asking?Agreed, my fatigue starts around 8 hour mark.![]()
