Redwingnine
- Sep 1, 2013
It will if you put Elear pads on it. AFAIK the Elex is an Elear with a different paint scheme and pads. The pads, however, make a very big difference, and some aftermarket pads, like some of the Dekoni ones, will completely re-tune Focals to the point that they don't even sound like Focals anymore.
I will probably get some Dekoni pads for the Utopia and try to EQ them closer to neutral, and report back on how that works. Focals are tricky to EQ because a lot of their treble peaks are very narrow, and you have to use high-Q filters in your EQ - which degrades the sound - if you want to have a completely linear FR. So you have to choose between having a linear FR but maybe degraded imaging and detail, or keeping the technical performance but maybe not having them sound totally linear. Right now I'm choosing the latter and my Utopia sounds a bit like a somewhat darker HD600, which is not a bad thing in my book. But from the measurements I've seen Dekoni pads smooth out the FR and tame some of the peaks, at the expense of being less neutral and not as balanced overall, and this may make it possible to use less degrading EQ and let you get closer to neutral while keeping technicalities intact.
However that's just the theory. We'll see soon enough. There's more to sound quality than just the FR, and I didn't like either Clear or Elex pads on the Utopia at all.
I also ordered a pair of Dekoni sheepskin pads. I'll post an update next week. I'll be keen to get your feedback.
