Finally getting a chance to have a listen to my Clear pro OG with the new Stellia LE Dekoni's on them, rockin out on a early Sunday morn while everyone sleeps in. Cable is another that I really like, made by Hart Audio.
I like them very much but I do prefer leathers against my skin, well I guess it's just skin on skin lol. The foam is a bit firm, though the OEM pads foam is way too soft, not quite Goldilocks for me but close. With a bit of rolling and wearing in they'll prolly end up perfect given a few weeks
Well it's still putting a pair of "closed" earpads designed for a closeback headphone on an openback Clear, so I think it will add a bit more bass for the Clear. One review on Dekoni's page says its adding a good 1-3 db, lines up with what I read on the other forum linked on the previous page.
Got those Dekoni stellia pads. Super soft, super plush. Probably one of the softest things I've ever touched. But for sound I don't notice any differences except maybe a 2% soundstage and imaging increase. They will need more "burn in" time for me to properly asses.
And yes I said pad burn in. This is headfi. Everything needs to be burned in :V
I got myself a Khadas Tone 2 Pro DAC/Amp combo and I've started to use it with my OG Clears, now I'm wondering if the output of the Khadas is enough to get the most out of the cans or should I get a separate amp for it.
One vote here for topping A90. I had the original MD aaa 789, and I like the A90 way more. That may be a slightly unfair comparisson as I only had the topping D70 with the 789 and I use the A90 with the D90.
If you're looking for bass extension, just use EQ. Personally, I think people should get the most naturally reproduced sounding dac/amp, then custom it after the fact with EQ. Just my opinion though
Dekoni Stellia LE pads, ZMF pilot pad...and super glue. The pilot pad fits but its so tight of a stretch that the velcro pulls off after a light touch. So I super glued the ends of the pilot pad together then gave one more line between the crease for good measure. There is no glue touching the Clear headband.
I feel with this the Clear's headband and earpads can now be cleaned, are more comfortable, and offer a better aesthetic.
