Focal Clear headphones
post-15528100
Post #6,871 of 6,880
andresnol
Tallinn
Tallinn
I dont get some people. A modern washing machine is anbe to clean the most expensive Kashmir wool pullovers, they have special cleaning cycles for sensitive stuff (I use it on my pads with no harm) and here you have people rubbing these pads while washing the pads by hand in a tub.
Better ask your wives next time.
I'm not married, but I wish I would have been before I washed those damn pads.
post-15528190
Post #6,872 of 6,880
Tekunda
STUTTGART
STUTTGART
That may work for the grey ones but as I said: the red ones bleed color like crazy. Tossing it in with other sensitive laundry is not advisable.
I am not going to let my machine (which has such programs) run on 2 headphone pads alone. What a waste of resources. Oo
It depends. If you want to save the world, wash the pads in your sink, if you want to save the pads, use the sensitive cycle on your washing machine.
But jokes aside, a wool cycle, luke warm water, just the pads (my machine weighs the load and adjusts water and detergent accordingly) will probably use less than 5 gallons of water and a tiny bit of electricity. Don't you think that $200 pads aren't worth that little extra care?
post-15528206
Post #6,874 of 6,880
roskodan
US/EU/IL
US/EU/IL
@Tekunda I washed mine in lukewarm water without rubbing, just lightly pressing them like a sponge, still they disintegrated after a while. If you put the Clear pads in a washing machine, I'm pretty sure it can only be worse.
post-15528371
Post #6,876 of 6,880
adydula
Then carefully wash them in small bowl, with some woolite...also my Samsung washing machine has a sports or active wear cycle that uses a very small amount of water.
Cost of water for a small load? vs $200 pads???
post-15528490
Post #6,877 of 6,880
roskodan
US/EU/IL
US/EU/IL
I guess I should've used wool detergent :deadhorse:.
But, the sound and comfort of my woolly pads is at least 2-3 tiers above vs new pads :L3000:.
I'm willing to offer Clear pads modding service to head-fiers, for the cost of shipping plus a small fee :beerchug:
Order your WoollyClear pads NOW!
post-15528554
Post #6,879 of 6,880
Slim1970
St. Louis, MO
St. Louis, MO
So guys , what amps are you using with your Clears?
I've tried them on several different amps so far. The Headamp Gilmore Lite Mk2, the Cavalli Liquid Carbon 2.0, the Burson Bang power amp, the Chord Hugo 2, and my favorite so far is the Burson Conductor 3X. The LC 2.0 is also a great pairing. Powering them from the Bang power amp was overkill, but good grief did the dynamics and bass come alive.
Reactions: Ichos
post-15531785
Post #6,880 of 6,880
Goldvein
Spain
Spain
am I the only one who thinks the squeaking can get really annoying when using the clears for watching something?
i use them A LOT for music, and I don’t notice it enough to really think about it, but now I’ve used them twice to watch series, and when it’s quiet, I keep hearing the headphones squeak.
I don’t imagine that there is, but I thought I would ask here if anyone has a solution for it?
Users Who Are Viewing This Thread (Users: 0, Guests: 6)
