Without the balanced cable, it would be a definite pass for me. Luckily I already own the Clear but if I had to buy the Pro right now with no balanced cable?....no sale.
Focal Clear headphones
- Thread starter mtoc
- Tags
- focal focal clear
balanced cable arent expensive though, you can easily find non-focal branded ones for cheaper on amazon.Without the balanced cable, it would be a definite pass for me. Luckily I already own the Clear but if I had to buy the Pro right now with no balanced cable?....no sale.
Emmanuel Palmer
Yes Same dual mono plugs like the normal clear. I have been using the clear professional for 2 months nowbut its using the same dual mono plugs into 3.5/6.35 jack.
TSAVJason
Sponsor: The Source AV
Get with it guys it’s called the Clear Pro because it is intended for studio use as a single ended headphone because that’s what they use.
TSAVJason
Stay updated on The Source AV at their sponsor profile on Head-Fi.
baiyy1986
Not gonna buy some cheap cable if I keep this baby but yeah, I think the original price is a little ridiculous, but with 999, I think the price is fair plus around 300 will have a decent set of cable.balanced cable arent expensive though, you can easily find non-focal branded ones for cheaper on amazon.
i dont spend more than 60ish $ for cables, unless its like a super unique termination thats harder to come by or unique type of cable, eg: (Stax cables, 4 pin xlr, 3 pin xlr, TH900 cable or Blue headphone extended 3.5 cable.)Not gonna but some cheap xlr cablenif I keep this baby but yeah, I think the original price is a little ridiculous, but with 999, I think the price is fair plus around 300 will have a nice set of cable.
but for a basic 3.5 to 3.5/6.35 or 2.5 to 3.5/6.35 i dont hear a difference at all in quality compared to a 20$ amazon cable or OEM cable from the headphone box.
TSAVJason
Tell me how you came to that $60ish number. A good balanced connector is at least 25% of that number. Connector quality is pretty important in a cable
TSAVJason
https://www.amazon.ca/NewFantasia-H...id=1545068654&sr=8-3&keywords=4+pin+xlr+cableTell me how you came to that $60ish number. A good balanced connector is at least 25% of that number. Connector quality is pretty important in a cable
this is roughly around the price i look at for after market cables, i've never had any issues with breaking or loss of connection from an end.
TSAVJason
I guess my point was I’m not thinking you’ll see much differential with products under $100 but over that you might experience more audio quality transfer
TSAVJason
Lol. Get with it guys? Sorry Alan I (we) didn’t read up on this pro model thoroughly enough to see that’s only what it’s used for. Sorry if I (we) ruffled your feathers. Peace!Get with it guys it’s called the Clear Pro because it is intended for studio use as a single ended headphone because that’s what they use.
TSAVJason
it wasn’t Alan it was me. No ruffled feathers here thx for your concern. I was trying to point out that complaining a pro device doesn’t have consumer connections is kinda silly don’t you think? It wasn’t intended for consumer use is my point.
TSAVJason
Luke Thomas
When The Elears came out many stores were promoting them as.. phenomenal headphones. after they were out awhile, their flaws were discussed a lot. Making them not quite as good as originally thought.
My question is. Are the Clears, proving to be as good as originally discussed?
TSAVJason
Excellent question! My comment is weighted from a “Dealer” perspective and specifically my dealer facility. The initial Elear failure issue was unfortunately pretty high. The Utopia also had failures but to a much lower degree. If our sales of the Clear are a fair sample rate of the failures, the rate would be 00.888%
TSAVJason
I think they're quite good especially w/ recent $1K sales. I see Clear as >90% of Utopia sound for <50% the price.
I think @Luke Thomas meant ‘sound flaws’ (perceived midrange dip) rather than failure rate. So does the Clear have any ‘flaws’ that were masked over by the hype and that have been exposed since the hype died down. If the hype has indeed died down...Excellent question! My comment is weighted from a “Dealer” perspective and specifically my dealer facility. The initial Elear failure issue was unfortunately pretty high. The Utopia also had failures but to a much lower degree. If our sales of the Clear are a fair sample rate of the failures, the rate would be 00.888%
Total: 7 (members: 0, guests: 7)
