Sorry for OT
Nice review. I think i would go to a higher price range though maybe around 2k-2,5k. Havent happen to here eddie current?
https://www.head-fi.org/showcase/eddie-current-zana-deux-se.14465/ ...
... I think a clear would compliment hd800s well. Or run over it?
The Zana Deux is a great amp but it wasn't for me. I still remember listening to HD800 on it. This is years ago when I was poking around, entertaining the idea of getting the HD800. I said to myself "bah, if this is what HD800 sounds like on a high end amp, I am not missing much, not owning a pair". Then I went to Woo booth... Long story short, after listening to HD800 on WA22 I bought both. The combo just clicked for me. The better combo was with WA5 but the difference in SQ didn't justify the cost for me. When I stumbled on Kenrad VT231 driver NOS tubes for the WA22, the urge to upgrade to WA5 stopped.
Regarding the Clear running over HD800, I don't think that will be the case. The PC answer would be the Clear might be the better choice...
If I could only keep one, I will be the Clear. It's not because the Clear is technically "better" but it's because the Clear is more enjoyable, easier with source, easier to drive (mobile friendly impedance), better bass slam for a wider range of genres (just as deep but a bit less texture than HD800), better tonality; all that + on top of very good technicality and resolution. On the other hand, HD800 is just so darn picky. For me and IMO, even when HD800 sounds "right" through its better technicality, soundstage, and bit more resolution, it still doesn't convey the same emotion nor pamper me with the euphonic listening experience as the Clear.
In my case, I will keep the HD800 knowing what it can offer. HD800 will complement the Clear, not the other way around. The HD800 will still be the go- to HPs when I mix and master my tracks due to its undisputed ability to pick apart everything. I still prefer listening to flamenco on HD800.
To my ear and with my setup, I think HD800 is also a bit faster. It's kind of confusing that the Clear will come at you with such dynamic + speed thus fooling you into thinking it's the faster HPs but when listening to the same track at low volume, HD800's effortless and better speed clearly showcases. I believe this is due to HD800's much bigger driver.
If someone asked me for advice regarding which HPs to purchase in the 1k range, the answer would be "get the Clear, save yourself some headache and $, and just start enjoying your music."
