jtinto
The Clears do sound better with my Bryston BHA-1 balanced, but they're just as enjoyable and getting more head time with my A&K Kann. They make a really nice combination with the short cable.
How well does chord mojo drive them or hugo 2? And comparisons between them driving the clear would be nice.
Also would clear with hugo 2 be a better system then hd800s with hdv820? Anyone have compared?
Price range from Mojo to Hugo 2/HDV820 is rather huge. My Samsung Note 8 drives the Clears well, but I wouldn't use it as my goto device for multiple reasons. There are a lot of DAC/AMP choices without needing to spend $2000+ and drinking the Chord Koolaid...lol
Can anyone recommend a good warmer amp for this headphone? I wish these had a slight more bass and tamed the treble just a bit. Budget up to $2k but pref $1k
i employ the rogue rh 5 but i do not currently have the clears.Can anyone recommend a good warmer amp for this headphone? I wish these had a slight more bass and tamed the treble just a bit. Budget up to $2k but pref $1k
Aune s6 probably.
I haven't heard any listening reports, but you might run into damping factor issues with the low input impedance of the Clear. S6 output impedance is 10 Ohm (20 Ohm balanced). Rule of thumb being generally that it shouldn't drive headphones with input impedance of less than 80 Ohm. Of course, it can be a little more complicated than the general rule of thumb, but most modern headphones seem to be designed for low output impedance. If someone has impressions of the pairing versus other, lower output impedance amps, I'm all ears.
As for suggestions for the original question, I've heard good things about the Questyle CMA400i.
You didn't mention of you were looking for a desktop or portable solution. But I recently started using a Woo WA7. It's not too "tubey" - just slightly warmer. I've been very pleased with the sound.
Finally got to A/B the Clear today against my HD 800S. I was very impressed by the clear i have to say. My local store will hopefully have them in stock in May. Much more bass and oomph. Soundstage was very impressive as well. Not as comfortable as the 800S.
How much is that i.e.m ?Actually I find the UE 11pro very similar to the Clear.
