Focal Clear headphones
Discussion in 'Headphones (full-size)' started by mtoc, Oct 1, 2017.
210 211 212 213 214 215 216 217 218 219
221 222 223 224 225 226 227 228 229 230
  1. strojo
    As mentioned previously a few times in this topic, other than cosmetic differences and different cables/extra ear pads in the box, they are the same headphone. They will sound the same.
    endressth likes this.
  2. Skyyyeman
    Thanks, unfortunately I let my subscription lapse last year, as I have moved more to headphones from my big system. (This has been going on for several years.)
    So, any chance you can provide a few pithy quotes from the article? Such as from the Conclusion or other relevant sections? Thanks
  3. bgbkt
    Has anyone tried new Lyr 3 or upgraded Jot with Clear? How's the synergy?
  4. Wildcatsare1
    Steve found it to be a “high performance, highly musical earphone.” I’m not able cut and paste from the site,
    I have a Lyr 3 arriving Monday.
    bgbkt likes this.
  5. happy hopping
    how's these 2 compares to Sennheiser HD 820? anyone try out the Sennheiser for comparison? I always want to know the difference btwn. Sennheiser HD 820 vs. a Berylium headphone
  6. BunnyNamedCraig
    I didn't get to spend much time with the HD820 when I was in CanJam NY. I believe its a closed HD800s essentially.
    I regards to comparisons, the Utopia is faster. Sadly that's all I can report on the matter ha.
    I will listen to the HD820 again at some point. I just wasn't in the mood to try and push my way through people to be able to hear it longer in NY.
  7. happy hopping
    faster would be right, as that's the whole deal behind berylium, it's light and hard, so it response fast.
    But to jump to $4K, out of interest, does anyone knows what really is the cost per gram of this material, and how many gram is on their headphone?
  8. herrsmith
    I strongly suspect that the machining is much more expensive than the bulk material cost. Beryllium is great, but it's pretty nasty stuff. It's not cheap to protect people from it (and to demonstrate to the relevant authority that you're doing so) while you're shaping it into what you've designed.
  9. happy hopping
    but I do a search on this material, it's sealed, so you can't get poisoned from it.
  10. herrsmith
    I would be incredibly surprised if there were a way to seal the material in a way that makes it safe to machine. The dust is the real danger, and machining creates a whole lot of that.
  11. nlwouter
    i just noticed Massdrop doing a drop of Dekoni focal pads:
    https://www.massdrop.com/buy/dekoni-premium-ear-pads-for-focal
    I would like to just give my clears a tad more oomph like the elears had, you guys think pad swapping wil help with that?
    And if so which type of pad would be the best. i don't have much experience pad swapping.
    I'd also like to know if anyone tried the Elear pads on the clear and if it sounds any good.
    Thanks in advance.
    snafu1 likes this.
  12. snafu1
    I'm with nlwouter. Can anyone explain what might be the audio difference between sheepskin, velour and hybrid. Maybe someone here has some experience with these Dekoni pads?
  13. kino lau
    Given that replacement Focal pads are in the $200 range retail, I wouldn't expect a whole lot for $40 from Massdrop.
  14. snafu1
    Price doesn't always mean performance. In addition, the price Focal charges for their replacement pads is absolutely ludicrous.
    pure5152 and noplsestar like this.
  15. nlwouter
    Yes i was about to say the same thing.
    Focal uses there accessories to gain a little bit of extra revenue. The production costs are nowhere near the asking price.
    Plus Dekoni is a well known pad manufacturer.
    I just want to know what the possible sound change would be from swapping.
    i already trust the quality.
