Focal Clear headphones
Discussion in 'Headphones (full-size)' started by mtoc, Oct 1, 2017.
205 206 207 208 209 210 211 212 213 214
216 217 218 219 220 221 222 223 224 225
  1. nanaholic
    The Clear headband looks replaceable to me. There's two screws on each side of the metal mount at the end of the headband where the sliding mechanism is, I'm betting loosening those would separate the driver mounts from the headband and you can then slide in a new headband.
  2. chungjun
    Practical consideration I would say. Well... for me, I’m using a headband cover to hopefully prolong the need to change the headband.
  3. kino lau
    That's nicely done. What did you use and how is it kept in place?
  4. BunnyNamedCraig
    I LOVE this. The color match was pretty on point as well!
  5. NickedWicked
    Damn, I need that for my Clears, looks very comfy and slick too!
  6. chungjun
    It’s held together by press-buttons. The buttons have padding in between them and the headband (see pic with thumb). Maybe photos from different angle will help... (see below)
    I got these from local re-seller in Singapore (PM me if you're interested in getting one in SG) but I did a google and do see something similar (I can't confirm its the same) on Amazon (https://www.amazon.com/Headphone-Sennheiser-Audio-Technica-Replacement-Protector/dp/B00OF71WWO).
  7. herrsmith
    I have the Amazon item as padding for my work M40X. It works pretty well, but be warned that the "red" is definitely pink. It looks exactly like the pictures. I was fooled by them calling it red in the description.
  8. up late
    it's like a cardigan :wink:
  9. chungjun
    Ahh... not for Clear Professional then... black one might work though.
    Sexy one I hope :smile:... it's showing quite a bit of skin viewed from the top. Hahaa!
  10. Paulo Abreu
    Hmmm... thanks for sharing, I guess I'm gone give my wife one hour labour work.
  11. devilboy
    So no one has used Black Dragon cables with their Clears? Or any other cable besides Norne? The 10 food stock cable will be too short for me so I wanted some feedback on others.
  12. devilboy
    Also if you do use another cable, please describe why. Meaning, was there something negative about the Clears that another cable helped tame?
    Matro5 likes this.
  13. kino lau
    Nothing wrong with the stock cables. My experience with aftermarket cables has been nothing but positive. I spent a lot of time researching different cable manufacturers and reading customer reviews before finding what I wanted. Some folks believe that wire is wire and that premium cables of any sort are nothing but snake oil. It's not been the case in my experience. I will only buy from Trevor for many reasons. The Solvine cable that I received yesterday sounds sensational and I'm extremely pleased with my decision to pick up a cable that utilizes both OCC Copper and OCC Silver. My IEM cables are pure Silver and that's all I have experience with. It's too soon to be able to express the difference that the new cable presents, but I've decided to use that tactic that is often used in stereo shops. Start with a higher performing piece of gear than what the customer is looking for, and then let them listen to what's not there in what they came in to buy. So I'm going to spend time with Clears and the new cable from Norne, and then try the stock cable again down the road to hear the difference (if there is any at all). It's just my preference to buy a handmade premium cable instead of using something mass produced. It could entirely be a placebo effect and everybody that believes that there's no difference might be right.
    :wink:
    Wildcatsare1 and brianc0428 like this.
  14. DavidW
    I've been in contact with the U.S. Focal support and wrote this morning asking about a replaceable headband. Here is the response:
    On Wed, Mar 28, 2018 at 11:40 AM, Eric Adler (Service) <service@audioplusservices.com> wrote:
    David,
    The headband will be available as a part eventually. I have the parts list, but not the prices yet.
    Take care,
    ERIC ADLER
    FOCAL NORTH AMERICA // S U P P O R T & S E R V I C E
    8 0 0 . 6 6 3 . 9 3 5 2 x 9
    Wildcatsare1 likes this.
  15. kino lau
    I believe that Eric was the same person that informed me that the Clear Professional was going to be tuned differently than the Clear. Similar to what they did with the Listen and Listen Professional.
