Focal Clear headphones
Discussion in 'Headphones (full-size)' started by mtoc, Oct 1, 2017.
204 205 206 207 208 209 210 211 212 213
215 216 217 218 219 220 221 222 223 224
  1. Raphael DeLaGhetto
    Why not?
  2. TSAVJason
    It’s not modified by anyone other than Focal to meet the price point that it’s at. Again this is according to Focal.
    The Source AV TSAVJason Stay updated on The Source AV at their sponsor page on Head-Fi.
    https://www.facebook.com./pages/The-Source-AV-Design-Group/153623164648713 http://www.twitter.com/TheSourceAV http://www.instagram.com/Thesourceavdesign http://thesourceav.com/ Products@TheSourceAV.com
  3. Wildcatsare1
    The Clear Professional comes with only the 1/4” plug and a coiled cable, versus the short 1/8”, and longer, straight, 1/4” and 4 pin XLR (@TSAVJason and @MTMECraig please correct me if I’m wrong), plus the color scheme. Functionally, they are the same headphone, I’m loving mine. Though I just added an Abyss 1266 to the Herd, to serve as the Yang to the Clear’s Yin.
  4. paul2qute
    OK mate must of read it wrong
  5. TSAVJason
    No balanced cables with the Pro. We’ll be showing both side by side at SoCal CanJam. Along with a whole bunch of new goodies.
    Matro5 and Wildcatsare1 like this.
  6. ChasingDopamine
    i thought the pro came with a straight 1.3m 3.5mm cable as well a coiled 5m 1/4inch
  7. kino lau
    It does. I've got my new aftermarket cable arriving Monday. So the stock cables will never again see the light of day.
    :relaxed:
    brianc0428 likes this.
  8. devilboy
    What cable did you get?
  9. ubs28
    The handband of these headphones goes dirty quite quickly it seems.
    What do you guys use to clean it?
  10. kino lau
    I picked up a Solvine from Trevor at Norne.
  11. herrsmith
  12. Skyyyeman
    Yes it's a concern to some of us. Here's what I posted awhile back:
    Cleaning the Alcantara
    First, it's been confirmed that the fabric is Alcantara (maybe this has mentioned previously someplace.) At Can Jam NY I spoke with one of the Focal people at the Focal booth who confirmed this. I asked if it could be cleaned and he said it could and recommended the following:
    (1) Alcantara cleaning kit (there are quite a few) available online or at an auto supply store. He said this is the preferred way to clean the Alcantara
    (2) Clorox Wipes - He said you can use this but it's not as good as an Alcantara cleaning kit and cautioned to only dab the wipe on the Alcantara, NOT to rub it.
    Personally, while the Alcantara can be cleaned, per above, for the headband I prefer to keep it entirely clean by wrapping some fabric (black or gray) around the headband and affixing it with some.tape. It adds a bit of padding and moisture absorption and doesn't look bad at all. Not that I care -- it's usually just me who sees it.
    Edit Report
    prfallon69 and makan like this.
  13. Skyyyeman
    Yes it's a concern. Below is what I posted awhile back: Update: Regarding material to wrap around the headband, I've been using an Ace bandage with some medical tape at the end so it doesn't unwrap. (Don't laugh I'm a sensitive guy.)
    Edit Report
  14. ubs28
    Ok cool, many thanks.
  15. Skyyyeman
    BTW, regarding cleaning, the reason why I was concerned about keeping the Clear's Alcantara headband clean and even covered was because the headband is not removable or replaceable if it gets really cruddy. And even cleaning it would not take all the dirt off. By contrast, the Clear's earpads can eventually be replaced if they get really bad. Replacement earpads for the Clear are not yet available but when they are will likely have a high price since the Elear's replacement earpads are $150 per pair and the Utopia's a massive $248 per pair. So what would be a guess for the Clear? Maybe the midpoint between the Elear's and Utopia's earpads which would be $199 per pair.
    It's a shame the Focal headphones are not modular so parts could be obtained and installed by the user. But, you can't have everything in life.
