Fafner
- Oct 26, 2003
I asked. UK means Upgrade Kit, nothing to do with country.Thanks I wonder if the module is specific to the voltage you choose when you order a Volot since it says UK on the back
Is it a simple addition, not a replacement?I just performed the upgrade, was fairly easy. The trickiest (or better, most annoying) part was to reput those tiny black screws in place.
The board doesn't actually replace something in the amp, but sits in between, very near to outputs.
How's the sound? hasn't worsened?I just performed the upgrade, was fairly easy. The trickiest (or better, most annoying) part was to reput those tiny black screws in place.
I would like to receive the kit quickly.
My Volot is resting too much
Haven't really listened much to it since, I just had a quick go to check everything worked.How's the sound? hasn't worsened?
I received it today, since I'm using the "High Gain" mode, so I'm not going to install (yet).Among those who participated in the first batch, did anyone receive an upgrade kit?
envious!The upgrade has been installed. The sound is great, - high gain mode.
Low Gain is even better.
Which headphones?The upgrade has been installed. The sound is great, - high gain mode.
Now MrSpeakers Ether C Flow 1.1Which headphones?
Anyone using this amp with sensitive headphones like utopia/stellia/grado/meze etc?
Any background noise/hum/buzz? Usable turn of the volume knob good?
