When you say "was the best reference" does that mean he no longer is posting? That DAC thread was epic and his descriptions easy to follow, thanks for the link.
https://forum.hifiguides.com/t/call-for-some-active-moderators/13366/148
Inside the amplifier case, in the middle on the right side, clicks are heard after switching on. They are continuous, with pauses of several seconds. Music is not on yet. This is weird. Interestingly, this is only my Volot?
Wait there is a remote control with the FA-10?Is this is your amp reseting from the remote control's set volume until it reaches the knobs position? My FA-10 does this if I used the remote control.
Or is the clicking never ending for you?
Yup, I think I shown a picture of it. If you search my name in this thread. (Using the website magnifying glass in the top right corner)(set it to "this thread" and then look down and put By member Infoseeker).Wait there is a remote control with the FA-10?
Glad your issue is fixed. This happened to me a bit with the FA-12 but the same solution works to get rid of the clicks. Was the volume knob at zero when the clicks happened or had you moved it a bit to get the clicks to happen? I'm curious because it would be weird if this happened at zero but would make more sense if it was happening when the volume was set to something other than zero.The problem has been resolved. Flux Lab's answer:
This can happen if the position of the volume knob is between two steps of the knob. This happens quite rarely. To remove it is enough to slightly turn the volume knob to either side to move to the next level of the regulator. It is absolutely not dangerous for the amplifier.
Who has the module been sent to?FLA) To eliminate the defect as soon as possible, we will send a module that is installed in the amplifier without soldering and does not require special skills.
Haven't heard anything from them since this message. That was the 3 September.Who has the module been sent to?
