Question for those in the know: does IEM FR change at different volume levels? I know that's probably a silly question, but I notice bass response, for example, is more prominent with some IEMs as volume increases, which got me thinking that this must affect the overall FR (or at least FR perception). Which also means we should be able to dial in a certain volume level on an FR graph and see what the IEM is doing at that volume level - otherwise what we're looking at may not be representative of the IEM at our personal listening volume.
I talked about this a while ago and it's - as
@fzman mentioned - related to the Fletcher-Munson curve. Basically, the bass will drop off a cliff as you drop the volume, and it'll perceivably rise the most as you increase it. As
@mashuto said, though, that's only in relation to how
our ears perceive the sound. An IEM, when driven at a higher or lower volume, will still read exactly the same in a frequency response graph, because a microphone doesn't work exactly like our ears and brain do.
Below, I've taken three quick measurements of the A18t. The middle one is control (or the reference), the one above it was taken after I increased the volume of the amp, and the one below it was taken after I reduced the gain on the measurement mic:
As you can see, whether I changed the load on the amp or the gain on the mic, the curve comes out exactly the same. So, when it comes to
reading graphs, those parameters shouldn't really matter.
When it comes to listening though, it does matter quite a bit. I always write my reviews with the assumption that the IEM is listened to at an average or listenable volume; when dynamics sound life-like, and when any outside noise whatsoever is completely drowned out. But, there have been scenarios where listening volume is a relevant factor. When someone says an IEM is brighter or warmer than they expected based off of reviews, then it's valid to ask that volume they heard it at. Like I mentioned when I did talk about the Fletcher-Munson curve, it's also a semi-viable way to
ever-so-slightly tune your IEMs as well by driving it louder or softer.
