Aug 1, 2016 at 11:39 PM Post #4,696 of 7,931
Dear Friends:
  When you try tips from other sources, please be careful, not to use tips which is too tight for FLC8s, the bore, which mates with the nozzles, is glued to the housing, if the the tips are too tight, the bore can be put off if you pull the tips too hard.
Aug 1, 2016 at 11:46 PM Post #4,697 of 7,931
  Dear Friends:
I think you meant to reply my pm... :S So the nozzle IS glued to the housing??
crap....
Aug 2, 2016 at 12:02 AM Post #4,699 of 7,931
crap
Yes, the bore was glued to the housing, you can return those to us to fix for you, or you can buy a bottle of Lotite 460 or 410 to glue it by yourself, if you choose to glue by yourself, please put enough glue, in case of leaking.
Aug 2, 2016 at 1:07 AM Post #4,701 of 7,931
Does Epoxy works (Since is plastic)? I'm worried that I apply too much and glue the dampening filter as well ._.
Would the sound be affected it it is broken? If I put it back in it seems to hold in itself pretty tight.
Aww, meng. Did you pull one of the nozzles off?
I've actually had a nozzle pull off another pair of IEM. Thankfully it hasn't happened to my FLC8S!
Yea... This is the first time it happen to me.. Pretty shocked..
I hope that's a lower price tier IEM that you pull off it's nozzle..
Aug 2, 2016 at 9:33 AM Post #4,709 of 7,931
Without spacer on the flc with spiral dot would sound very mid forward and the bass are not really having a lot of impact.
With spacer and spiral dot, the mid feel a little distance but this makes it sound really airy. This time the bass hit pretty deep. I think most probably due to the spiral dot design. Oh and wider soundstage with jvc spiral dot.
That's just what I heard. :)
